Violet DSP Evolution - an Open Baffle Project
Old 1st March 2010, 12:33 PM   #31
StigErik is offline StigErik  Norway
StigErik's Avatar
Your right - PLParEQ is very CPU heavy, and the latency is loooooong. Price.. well, it depends. The full version is 1000$, not cheap, but I think its worth the money. More value than expensive cables at least.....
I have a 1.8 GHz CoreDuo machine, and running 4-way XO with EQ on this is difficult, I'm balancing on the edge so to speak, with 97% or so CPU util.....
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 1st March 2010, 04:45 PM   #32
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I dont know, but I have plenty to do keeping my PC up to date, but it wears out none the less
A good friend renews bits and pieces when needed, just to keep my PC running, until I need the next generation (in about 2years I suppose)
But using a PC seems to me like it could be a more costly approach in the long run, all considered
And a PC is pretty noisy, in more than one way
Or maybe I have no idea how it works
Old 1st March 2010, 05:57 PM   #33
twest820 is offline twest820
My experience with my 1.7GHz CoreSolo is in good agreement. As for value, Allocator+PLParEQX3 arguably outperforms at 20% of the cost.
Originally Posted by tinitus View Post
But using a PC seems to me like it could be a more costly approach in the long run, all considered. And a PC is pretty noisy, in more than one way.
In my case it's cheaper and hugely easier to run a digital crossover on a laptop than an analog crossover. Laptops are quiet, too.
I didn't mean to initiate a thread hijack; we should probably move this aspect of the discussion over to the digital line level forum. Feel free to start a crossover TCO thread over there.
Old 1st March 2010, 09:18 PM   #34
Bratislav is offline Bratislav  Australia
Originally Posted by keyser View Post
You can read about it here: MOB3W - my open baffle three way
Ah, yes, I've seen it! I think he's now going "naked" too (mids+high) if I'm not mistaken ?
That design has all the potential to be truly formidable contender. If you felt it was better than Orion that is high praise indeed !!!
Old 2nd March 2010, 02:53 AM   #35
cuibono is offline cuibono  United States
cuibono's Avatar
Thanks for the heads up about PLParEQ - it looks interesting, but I'm not into long latencies.
I've been busy with things the last few days, but thought I'd share this pretty little graph. This is 0deg, 30deg, 45deg and 60deg. I measured it outdoors, 3.5m in the air, at 1.85m, and it is effectively ungated. 30deg is the listening axis.
Read it and weep! -6dB at 30Hz!
Old 2nd March 2010, 03:23 AM   #36
Dude, that is one sweet polar. How flat's the phase?
Allocator+PLParEQX isn't much worse than Allocator alone. Worth a look if, like StigErik, you find linear phase works best.
Old 2nd March 2010, 04:20 AM   #37
That is truly remarkable ! And CD without a waveguide ... who would have thought
Old 2nd March 2010, 04:38 AM   #38
sangram is offline sangram  India
A far less ambitious project:
Big Bertha!
I have yet to take measurements - but the reason I'm posting this here is that I use the E-mu1212m's inbuilt DSP to run the EQs for this pair of speakers. Up to 5 effects are allowed, I use only the Parametric EQ/shelf EQ effects. You do not need fancy software, the card's drivers have DSP abilities up to 48KHz. For the more upmarket 1616m, it can also perform duty of active crossover. CPU load is zero. Obviously it's not perfect, but a reasonable way to start a similar project.
Old 2nd March 2010, 09:05 AM   #39
Another option is the Focusrite Saffire 24 DSP. Haven't checked all the details see how it compares to the 1616. I believe Motu and Steinberg have higher end offerings as well. So far as I know no embedded DSP audio interface supports linear phase crossovers or equalization, though I won't claim to have looked terribly hard.
Old 2nd March 2010, 09:30 AM   #40
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Terrific! I am still wiping my tears off.
I have seen such a response only in simulations before. Considering that you could achieve this with such a modest system (cost wise) makes it even more remarkable.
Rudolf
www.dipolplus.de
Violet DSP Evolution - an Open Baffle ProjectHide this!Advertise here!
Question about Open Baffle project gvimhoof Full Range 6 3rd August 2010 08:20 PM
Need help for my first Open Baffle project anilva Multi-Way 8 22nd January 2010 12:00 AM
First open baffle project Moondog55 Multi-Way 18 10th August 2008 04:35 AM
open baffle project mastarecoil Full Range 25 29th November 2007 05:08 AM
another Open Baffle project Tomac Multi-Way 1 14th September 2006 09:11 AM
