Old 8th June 2003, 06:16 PM   #1
Default Audiophile version
I am looking into creating an audiophile digital crossover. As co-developer of the APOX volume control, I think there may be merit in a unit designed for best audio performance.
Instead of just allowing Nth order slopes, I am hoping to allow arbitrary mag/phase plots to be downloaded and the appropriate filter coefficients calculated. Of course, standard butterworth and other types would be supported.
I am not sure that a DSP is really needed for the calculations. I would rather use a couple of high speed microcontrollers or even a low end X86 type chip (built in FPU).
Could people list a few high level specs that they would like to be included...
In general, I was anticipating:
SPDIF or I2S inputs
Analog Inputs: 24/96 ADC
six or eight channels 24/96 DAC (3 or 4 way)
Digital output?
Volume control via PGA43XX or PGA23XX in analog domain
Etc...
Dale
doing my part to Keep Austin Wierd.
Old 8th June 2003, 06:42 PM   #2
jleaman is offline jleaman  Canada
Send a message via AIM to jleaman Send a message via MSN to jleaman Send a message via Skype™ to jleaman
Great idea. Got any sujestons and planns..
j'
Baby Danika, Born January 20th 1:54am..
http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect..
Old 8th June 2003, 06:47 PM   #3
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
You'll be a lot happier with a SHARC than with some x86 CPU. The performance per unit heat produced will be much much higher, and the pin count will be lower.
I've been playing with digital x-overs in software, and I'd like to see phase, slope, 3dB frequency, and passband attenuation all controlled in software.
I guess it really depends on how far toward the high end you want to go. Each channel could have digital outputs, single-ended and balanced analog outputs, etc. The main concern quickly becomes having enough room for all the connectors
Old 8th June 2003, 06:50 PM   #4
pinkmouse's Avatar
Great idea Dale
Ok, my suggestions-
Good to have
2 ins, and 3+ sub, or 4 +sub outs.
Option of balanced or unbalanced inputs and outputs
Programable/controlable via Usb and a Unix program, as users of both Macs and Pcs can get Linux/Unix running on their machines.
Adjustable delay for time alignment of drivers.
If possible
Linkwitz transform or other EQ on the sub or bass outputs
Maybe two or three bands of adjustable eq for room correction
Volume controls optional for those that don't need them.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 8th June 2003, 07:14 PM   #5
diyAudio Moderator Emeritus
roddyama's Avatar
Hi Dale,
Now you’re talkin’! I’ll think about this some more, but here are my first thoughts.
Digital time delay per channel
An extra channel per channel for notch filters, or baffle step comp., or FR tailoring.
Channel by-pass
Level per channel
System configuration memory and/or programmable pre-sets
Rodd Yamashita
Old 8th June 2003, 07:21 PM   #6
slowmotion's Avatar
Hi Dale ,
I would be interested too
8 analog outputs would be nice
cheers
Old 8th June 2003, 07:25 PM   #7
pinkmouse's Avatar
Rodd
Channel mutes perhaps, channel bypass could lead to blown tweeters
I think level per channel might be easier to handle in the analogue domain rather than digital, to save processing power, but hey, what do I know
At least two presets is definitely a good idea, then you could have one for music and one for HT for instance.
More general thoughts-
A pink noise generator for system setup would be handy...
Al
Old 8th June 2003, 07:40 PM   #8
roddyama's Avatar
Originally posted by pinkmouse
Rodd
Hi Al,
Yeah, I guess I could wire straight through channels externally. I thought about that because my Heathkit xover has a by-pass, but it is for the bass range only, so in general, you're probably right.
Rodd Yamashita
Old 8th June 2003, 08:00 PM   #9
Is this going to be balanced or non-balanced.
Will it be adjustable.?
will there be one main in and 4 or so out's..
My idea.
Main in
Sub out
hi out
mid out
low out
All adjustable..
Desplay ? yes no.?
Old 8th June 2003, 08:01 PM   #10
pinkmouse's Avatar
Another quick thought, a fixed high Q high pass filter at say 10Hz, for those of us that still use vinyl would be nice
Al
WTB : Apox IS1 Josep Swap Meet 1 3rd January 2007 07:58 PM
wtb: APOX-1 or similar Scott_fx Swap Meet 2 28th October 2006 06:10 PM
Apox Bosoz Brian Donaldson Pass Labs 8 31st August 2005 01:31 PM
P1.7 / APOX completed ARAD Pass Labs 50 8th December 2003 08:27 AM
Page generated in 0.23828 seconds (42.79% PHP - 57.21% MySQL) with 11 queries
