hi
i am planning on buy inductors for a crossover i am makeing i have calculated the values that i need but i dont know what type of inductor to purchase (sorry for my ignorance when it comes to this sort of thing). the values i am using are .07mH and 1.2mH any help would be appreciated. Kev |
#2 |
Kev,
have a look at:- Jantzen Audio Denmark - Leading coil and inductor manufacturer in Europe under their Products, then to Coils page. There is data about each different type, and some other relevant matters if you search further down that page. Jantzen inductors are well made, and are available via mailorder in the UK from Audio Components. You can find their web-site listed under Dealers on the Jantzen web-site.
Alan Last edited by alan-1-b; 20th February 2010 at 05:38 PM. Reason: to add a phrase |
#3 |
Look at their power (Ex:18ga/16ga, not mentioned here anyway, I'm not using the conversion tables but in mm you can use 0,71 D/mm for tweeter only and bigger 0.95, 1.2 mm diameter for woofer), some of the websites have the inductance L/mH, R/Ohm and wire D/mm.
For woofer or tweeter use (standard) Air-cored Inductor products. Ex: 18ga For woofers (low frequencies/high inductances) you can use Ferrite-cored Inductors. They usually have low R/Ohm (resistance). Ex:16ga Wire Gauge & Diameter Calculator Winding your own inductors Last edited by Inductor; 20th February 2010 at 05:47 PM. |
#4 |
Hi Inductor,
I think the Jantzen P-core, non-ferrite, type could work better than ferrites in the woofer filter if low resistance air-core too expensive for there.
Alan |
#5 |
Thanks, that's more information than phatkev can chew on.
#6 |
thanks for the replies appreciate it
kev |
#7 |
#8 |
If you choose a ferrite with good current capability, there is no reason to AVOID a ferrite core. smaller ferrite cored chokes can saturate at relatively low currents, i.e. 3 amps, but for my woofer LP filter i use a ferrire cored inductor with a saturation current of more than 10 amps. as long as you can minimise, or eliminate the risk of saturation, and the non- linearities it introduces you should be ok.
Its a case of Perception:You never stop being a 'Noob' (a term banned on many social gaming sites), Ego is the Thing that tells Us otherwise. |
#9 |
I agree.
Take the Speaker Voltage Test! |
#10 |
Say, anybody know exactly what the Jantzen C-coil cores are made of? Silicon steel tape, maybe? They say 'iron' in their advertising literature, but that doesn't sound so good for eddy currents.
| choosing inductors for crossovers | ark | Multi-Way | 12 | 9th March 2007 11:10 AM |
| Toroidal Inductors for crossovers | omni | Multi-Way | 12 | 1st December 2006 10:24 AM |
| big vs Small inductors in loudspeakers crossovers | qguy | Multi-Way | 2 | 26th October 2006 02:22 AM |
| Whats the purpose of inductors in circuits (not crossovers) | Hybrid fourdoor | Parts | 4 | 11th April 2004 12:13 AM |
| Ferrite Core Inductors for Crossovers | r_s_dhar | Multi-Way | 25 | 29th June 2002 05:32 PM |
| Page generated in 0.12158 seconds (68.23% PHP - 31.77% MySQL) with 10 queries |
