Old 20th February 2010, 08:59 AM   #1
gainphile's Avatar
Thumbs up My S13 OB. Uniform polar response to tweeters at last!
This next iteration of my dipole builds cannot happen without the following:
Keyser on Unbaffled Neo3 PDR
Cuibono on Tangband W4 dipole
Rudolf on small-baffle Tweeters
Saurav on Unbaffled Neo3
Mige0 on dipole horn
StigErik on no-baffle OB
Their dedication to perfection is unsurpassed. I really hope I haven't missed anyone for the credit.
I believe this finding is a major milestone in dipole speaker technology
http://gainphile.blogspot.com
Old 20th February 2010, 09:13 AM   #2
gainphile's Avatar
A bit of history first.
My first dipole was in 2007. In the beginning I thought the most difficult part was the bass. Turns out that the midrange EQ is not easy.
But then after understanding the midrange, it's actually the transition to tweeters that is problematic. The normal approach of back-to-back tweeters is a love-hate relationship. I couldn't decide whether it's actually better than single tweeter. At one stage I was considering to try waveguides/horns (shiver..)
After following closely (and quietly ) the above threads I built this prototype today:
"Tweeters" are 3" TangBand Fullrange.
... and what a beautiful polar response (un-eq for now)! Very consistent response up to 10khz. I haven't seen polar plot of well-known dipole speakers but this would be almost impossible to produce using typical back-to-back dome tweeters.
And so cheap too! Next is to build the EQ
What is surprising for me is how easy it was to set tweeter level. Just measure flat from 1m and I cycled through my music. All sounded well. Tweeter setting using back-to-back Dipole used to be very frustrating.
Old 20th February 2010, 09:20 AM   #3
frugal-phile(tm)
planet10's Avatar
That looks like a small version of Bud Purvine's rocketship OB... except he is planning a lowther up top.
You have me inspired to go read the threads you've linked.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th February 2010, 09:37 AM   #4
gainphile's Avatar
Yes, I followed BudP's plan as well. However the size of that Lowther may not allow good polar response near the last octaves. For a 6" perhaps up to 2 or 3 khz. Lower if the diameter is bigger.
What I want is a great 2" fullrange as this would extend further. I do not really need the low Fs (60Hz) of 3" speaker. I have aura nsw2 which works great with Pluto but the rear cavity presented problems as dipole.
Old 20th February 2010, 10:58 AM   #5
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Gainphile,
I really don't want to spoil the party, but what you show is not (yet) what the contributors mentioned above are trying to achieve IMHO.
You have got nice constant directivity up to 1 kHz, but above 3 kHz it is simply a beaming 3" TangBand. Between 1-2 kHz I see an intermittent beaming which I would relate to a less than optimal depth alignment of both drivers for that area - but I'm not sure of that.
Radiation to the back of the speaker will be VERY different from the forward too.
If you really want to follow the 'CD throughout' path you need to reconsider those "typical back-to-back dome tweeters", but changing to really tiny tweeters - or the Neo3.
Rudolf
www.dipolplus.de
Old 20th February 2010, 05:04 PM   #6
Looks good, gainphile! I agree that a 2" with a small rear structure might be ideal. The dipole D would be smaller than either the Neo3 or any back to back setup I've seen.
I don't know if you can still edit your first post but Keyser is using the Neo3 (non PDR) and Saurav is using the Neo3 PDR.
Dennis H
Old 20th February 2010, 05:15 PM   #7
fergs1 is offline fergs1  Australia
Greetings Gain, good to see you on the move again. The new baffles look great. Remind me what is the midrange you are using and what is your high pass on the mid(where is it crossing over to the h frame) cheers fergs
Old 20th February 2010, 05:57 PM   #8
cuibono is offline cuibono  United States
cuibono's Avatar
Nice work Gainphile - I really enjoy this sort of shared work environment, getting to informally collaborate and inspire each other.
I like your idea, definitely innovative. I would be interested in knowing how a 2" driver goes.
Rudolf does have a point though - the driver is beaming. Even the SL's Plutos beam, and I feel it is audible, and they use a 1" driver. Something interesting though - SL addressed that in his 2.1 revision - compare the transfer functions. The original Pluto has a flat on axis response, but the later version has a rising response at higher frequencies. I would wager this it to help even the power response due to the tweeters beaming, and I bet it is a nice improvement.
Good work!
Old 20th February 2010, 09:13 PM   #9
gainphile's Avatar
Originally Posted by Rudolf View Post
Gainphile,
Rudolf
The xo is at 2.4khz, so the irregularity 1-2khz is due to the midrange being pushed quite high. As I can cross the TB very low I will see whether crossing at 1khz will fix this issue.
With dipoles, we actually need to 'utilise' the beaming properties of drivers above dipole peak. So the frequency before the dipole dip is perfectly usable. Of course we can use the "pure" CD section that is possible too, but will be very expensive in terms of the number of drivers used.
I did measure the rear radiation, and it is different, but still very smooth to high octaves.
Old 20th February 2010, 09:15 PM   #10
gainphile's Avatar
The 2" I've seen so far have typical problem: the rear opening does not look good. Perhaps due to physical design constraints.
Thanks for the correction. I got confused all the time which one is which.
Importance of vertical polar response dantheman Multi-Way 43 8th January 2010 05:28 PM
Crossover Types and Polar Response? Tenson Multi-Way 7 26th January 2009 01:37 PM
MTM with BW3 and LR4 - Polar response HiFiNutNut Multi-Way 2 26th February 2008 08:52 PM
woofer in 2.5 way affecting polar response thadman Multi-Way 0 15th June 2007 04:49 PM
Beaming effect on polar response at crossover tiroth Multi-Way 13 3rd July 2004 10:25 PM
Page generated in 0.17707 seconds (61.83% PHP - 38.17% MySQL) with 11 queries
