Well, I was routing through the local thrift store when I came across some headphones.
Well, turned out to be STAX SR-40 for $5.99can. But the SDR-4 transformer was missing. Anyways, what should I do with them? I could build some sort of amp driver if I knew some specs. I don't want to spend any money on them if they don't work. Anybody know how I can test them? Anybody know anything? Thanks in advance.
My girlfriend's sub is bigger than mine...
#2 |
diyAudio Senior Member
The 40,60 and 80 are electret headphones and as such use a permanent magnet principle. From what I read about them a PSU is not required, the magnets getting polarised by passing the AC ( music) signal through them. UNFORTUNATELY IN GERMAN... Cheers,
Frank |
#3 |
The pair that I have in a box somewhere use a step-up transformer box.
I do not know the step-up ratio required, but you could probably try a small 240-15 transformer wired in reverse and see what you get. These use a permanent electret capsule, and as I understand it these can lose their polarization, and go low audio output level. I have replaced these capsules in a pair of Yamaha electret headphones in the past, and these looked like they could have been Stax oem. Eric.
I believe not to believe in any fixed belief system. |
| Stax CA-X Preamp | EchoWars | Solid State | 31 | 26th August 2009 09:48 AM |
| Stax electrostatic headphones | npdang | Swap Meet | 0 | 21st October 2004 07:33 AM |
| Stax SRA-12S | ObliVion | Solid State | 0 | 12th July 2004 01:29 PM |
| Stax SRA-12S | ObliVion | Solid State | 0 | 12th July 2004 01:23 PM |
| Stax SR-34 black box | Jennice | Parts | 5 | 1st August 2003 08:59 PM |
