Hi guys,
Wanted to know if anyone has heard of a Q POWER 280 watts 15" sub woofer driver. If You did ,do you have the specs for it,if not where can I get one? I don't know how many cu. ft. of box volume should I build a box for this sub. Any comments? Thanx, Tony |
#2 |
Consider that good speakers cost something close to the diameter squared (i.e. 6"-$36; 8"-$64; 12"-$144; 15"-$225) in US Dollars.
If you payed less than half that, you either got a really good deal or the speakers are junk. If you want to know the parameters, measure them. All you need is a resistor and your soundcard-equipped computer, a voltmeter and a couple cords (you can use the cords from broken headphones if you have any - as long as the cord isn't what is broken). Go to: http://www.kbapps.com/audio/speakerd...arameters.html and follow the instructions. You can download a tone generator program from the internet - a good one is called nchtone - do a search for it. The program takes the place of the generator and frequency counter, and the rest is easy. the main page has other good stuff, too and is at: http://www.kbapps.com If you don't want to do this, stick them in a sealed box of 2-4 cubic feet (60-120 liters) and live with what you get...
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
Q POWER 280 watts 15 -- This sound like a (crappy) car subwoofer, is it? Go to caraudioforum.com Mostly a bunch of Fast and the Furious wanna be buttheads if you ask me, but they might know what it is.
What's the name of the company that makes the sub? Look at the sub harder try to find the name or some clues. |
#4 |
your pretty safe with any 15 inch car audio sub with a 2.5-3 cu. ft box.....I have my Fosgate pwr12 in a 2 cu. ft ported box and it sounds decent
#5 | |
A 15" driver in a box 10cm by 10cm by 30 cm? So how long have you been a Timelord?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#6 |
LMAO...I meant cu. ft....thanks for correcting me on that..hahahaha
| How to calculate an enclosure with variovent ? | TomatoBangBang | Multi-Way | 4 | 16th January 2009 04:35 PM |
| Help calculate enclosure volume | Sillyboy | Multi-Way | 25 | 5th May 2006 11:22 PM |
| Calculate BL | Dave Jones | Multi-Way | 19 | 8th May 2004 01:16 AM |
| Opening a can of worms but...how do you calculate the slope inside a TL enclosure | Rino odorico | Multi-Way | 17 | 26th August 2002 05:57 PM |
| Page generated in 0.12352 seconds (49.44% PHP - 50.56% MySQL) with 10 queries |
