Old 15th February 2010, 07:02 AM   #1
alspe is offline alspe  Finland
Default Sensitive 2-way (pro woof + ribbon)
Has anyone tried simple construction using 8"-10" pro midrange/woofer + ribbon tweeter and crossed them quite high? High because ribbons don't like lower high's, you can keep distortion low. Directivity problem may occur because of woofer's directivity.
XO maybe 4000-6000 Hz depending ribbon tweeter?
Old 15th February 2010, 07:13 AM   #2
chris661's Avatar
You'll be looking for a pretty special PA driver that would go that high...
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 15th February 2010, 08:16 AM   #3
jerome69's Avatar
It's depends on the ribbon.
For pro application, possible if very well done, in general not very usable. Better use a compression driver. I never use a pro 8"/10" as high as 4..6kHz but in some case it is possible.
For HiFi, a ribbon can cross low Fountek NeoPro5i, you can cross as low as 1KHz with a pro 10"/12"
With a high sensitivity 8" you can use a neo CD 3.0 or a JP3 as low as 2kHz.
Old 15th February 2010, 08:21 AM   #4
Yes 6 kHz is bit overkill but some B&C woofs may handle 4000 Hz.
It think there is no reason to cross Pro5i as low as 1 kHz even if it could be. I have "heard" from DIY designers than ribbon can sound distorted if it sounds good on paper if you cross them low.
If you can strech woofer up to 4000 Hz you can handle treble with much cheaper and smaller treble unit.
Latest project, 3 way with 10" sealed woof Nortp Multi-Way 9 17th August 2007 01:15 PM
3 way - how to measure woof/mid xo point? Dave Bullet Multi-Way 7 22nd June 2007 06:29 PM
Woof Woof Woof! anatech The Lounge 4 12th July 2006 02:07 PM
Woof woof from New Zealand BlackDog Introductions 5 11th March 2004 09:01 AM
Best 10" woof Question apassgear Multi-Way 5 4th April 2003 08:52 PM
Page generated in 0.09493 seconds (64.09% PHP - 35.91% MySQL) with 10 queries
