On the directivity of dipole tweeters
Old 3rd January 2011, 01:05 AM   #111
RAAL is offline RAAL  Serbia
Hola muchachos!
mige0,
I was talking about compression drivers and horns. Having back radiation changes situation dramatically, I believe you. I've been around the block a few times, you know. See what I was playing with back in '95. It was during the war, so there was nothing better to do as economy was ruined. Nothing better than playing with Pass' Zen, SE tube amps, Moscodes, etc. and building speakers, he, he! Not so bad, hey! I did try the front back horn, too. When I mentioned the instrument size, I wasn't referring to HF, as I don't think the instrument size lays in that bush. More of a something below 1k5, but mostly between 200 and 1k. If you dry the room out of that with a dipole or a horn, you may, just may, get cleaner sound in general, but it still doesn't compare to a treated room with omni. Probably because it's not natural.
when i said 3x3, i meant 9, with 2x4 or 2x3, i mean 8 and 6 and with hex+1 in the middle i meant 7, used for midrange above 200Hz.
Of course, beaming gets very tight up there, but as you've said, no free lunch.
Hi Telstar,
Beyma 150 is an interesting beast! here's a plot of dipole 140-15D without acoustic lens. this will make a better comparison to the Beyma tpl150, as they're about the same vertical size. If you're not crossing low, and maybe you don't as you use 4-way, I don't think you'll loose much of the efficiency, if you don't mind the same beaming.
Aaaah, MAD planar. Designed by my first mentor, Dragoslav Colich for HPV. What a jewel that is! It plays so effortlessly relaxed, smooth and soft but with a slam and kick I've never heard out of a planar! Had a pair for a couple of months and living with those was sweet. Are they available now? They used to be $1k a pop...
I've been told great things about BG neo10. I think I'll get a pair.
I need to listen FAL somewhere. I'm very curious.
Well, for one Per Skaaning is the one that knows how not to overdo the ring thing.
Yup, multiplying them little critters will be the center of the new OB speaker I'll do, following that narrow midrange - wide flush HF approach. Not because it's easier done that pushing dipole high up, but because it still makes more sense to me. I know what I've heard and the "big midrange" does the trick for me when OB is in question. Well, if anything is in question, big mids are the ticket. By big midrange driver, I also think cluster of 3"-ers, just to be clear.
Fountek is a phenomenal value for money! I'll shake hands and take a picture with Fountek guys if I ever meet them.
File Type: jpg DIPOLE 140-15D freq response without deflector pads.JPG (75.6 KB, 486 views)
Old 3rd January 2011, 01:14 AM   #112
CLS is offline CLS  Taiwan
Thanks a lot for sharing. Very interesting dirver. Is that 'ladder' at the rear the magnetic circuit?
Old 3rd January 2011, 01:19 AM   #113
I just have to post this!
My first mentor, Dragoslav Colich, co-creator of Monsoon and creator of MAD planars. He's in shorts. We are listening to two panels consisting of 64 MAD drivers on a side, with 24 OB peerless XXLS 12" on a side, with a silly number of amps and power involved.
Now, that was something to remember! That 119dB was the average SPL, slow setting, C weighting. And there was no pain or anything that will make you turn it down.
Old 3rd January 2011, 01:25 AM   #114
No, the ferrite magnets are below the plates, those are iron bridges to close the flux. The XO is at 1k8 and it has 90 dB at the front with that assymetrical horn that allowed for very little towing in. It sounds silly today, but I didn't know better back then. Still, the nature of the beast was obvious.
Old 3rd January 2011, 04:51 AM   #115
mige0 is offline mige0  Austria
mige0's Avatar
Location: Austria, at a beautiful place right in the heart of the Alps.
certainly
Regarding round over's, horn's etc. things have slightly moved since then and perspective got shifted...
This is 1" driver at 2" round over :
Not that bad - but there is room for improvement...
Michael
Old 3rd January 2011, 06:16 AM   #116
keyser is offline keyser  Netherlands
keyser's Avatar
Originally Posted by john k... View Post
Well the Neo3 eq'ed flat on axis certainly didn't retain that response off axis for me. I don't see how that could happen as the dipole peal and first null mover higher in frequency as the off axis angle increases.
A lot of the theory on your website is based on the premise that the dipole peak shifts to a higher frequency when you go off-axis, but I don't think this is correct. It is true if you consider two physically separated point sources, but it is not for a back and forth moving plane. Then the dipole peak actually shifts to a lower frequency when you go off-axis. This has to do with the bulk of the sound having to move around the driver/baffle and thus having to travel a larger distance. The shift to a lower frequency can easily be measured, so I'm a bit surprised that you claim differently.
Dutch & Dutch
Old 3rd January 2011, 10:53 AM   #117
john k... is offline john k...  United States
john k...'s Avatar
That is not correct. To restate things a little differently, at low frequency where the response rolls off a 6dB/octave, that roll off is basically the same as a 1st order high pass filter with pole at the (theoretical) dipole peak. If the peak moved lower in frequency, the response off axis would be at a higher level that the on axis. It should be obvious that the effective separation between the front and rear sources must decrease because, obviously at 90 degrees the separation goes to zero or you would not have a 90 degree null. When we have a driver on a baffle the separation doesn't exactly follow the cos(theoretical) relationship, but the separation is a maximum on axis and becomes smaller as we move off axis.
You may or may not observe the movement of the peak higher in measurements because of other factors such as baffle size/shape, driver directionality, asymmetry between front and rear response, and the fact that the rear radiation that sums to the front acts as a distributed source around the baffle edge, but it is not uncommon to measure this effect.
Here is a simulation of a 20 cm driver centered on a 40 cm square baffle for the on axis and 60 degree off axis response. Yes, it is only a simulation but it is reasonable representative of measured data.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 3rd January 2011, 11:33 AM   #118
john k...'s Avatar
Hi John,
You're a highly regarded loudspeaker designer and your work is always thorough, it brought so much useful data to wide audience and it was always discovering the good features of affordable components, giving valuable advice to DIY community.
Surely, you must know what would you like to have, regarding dipole tweeters format. You can't just sit back and let me guess what it is. If you're not happy with current offerings, then please define what optimal is. You may be used to manufacturers that don't listen, but I do listen and try to do my best to serve the needs.
Because of that, I have question to ask you, after I point out one thing.
To the difficulties you noted, I would also add the sensitivity issue, which is disregarded here.
Let's not mix apples and oranges, as 90dB/Watt allows a speaker designer a completely different vantage point than 95dB/Watt.
If your choice of amplifier is, say, 25 Watt Firstwatt J2 or any other 15-25 Watt beauty out there, problems start to jump out of the closet. You'd be aware of the potential, but you wouldn't be able to use it with 90 dB/Watt speaker, and that is very frustrating. You'd want at least 95 dB/Watt speaker to match.
For example, closed 140-15 has 95 dB/Watt (not 2.83V), or more, depending on the foam pads positioning. The dipole version, due to increased air loading mass, has about 1.3 dB less with same response curve.
Experience shows that for a good tone balance of the loudspeaker, they both require about 1.5dB more efficient midrange due to dynamic compression issues on the midrange side and due to wider dispersion on the ribbon side.
The problem is that there aren't much mids out there that are churning out 96.5 or 95 dB/Watt flat responses and the ones that do that, are not small filler drivers, but 8" exotics, like Supravox 215 variety, Seas exotic 8, and such. No planars in the game, either.
The mid will start beaming fairly soon and you can't use a filler driver, because there isn't any variety of 4-5" 95 dB's to choose from.
Just 3dB, let alone 5dB in increased sensitivity demand by the customer, changes the game completely and 50 bucks is not considered a chip any more, due to exponential increase in difficulty of designing and building such a thing. 90 dB/ Watt allows much more liberty and it's easy compared to 95dB/Watt.
So, my question is, if you were to design a dipole 95-96 dB/Watt speaker, having in mind that you'll have to use an 8" midrange, crossing is as low as possible, what would be the tweeter format that you'd like to use?
I think I nailed it pretty close, for what it s intended for, but I'd like to know what would you do, if it ain't a secret.
I'm asking because I may want to provide certain features to the baffle so everybody would be happy.
One possible way to do this is to increase the iron yoke size, but drill a large number of 1/2" to 3/4" holes through it. That way, you can choose which holes to plug and which to leave open, creating different patterns that just might fit any dipole taste, without increasing efficiency.
Thanks for the compliment, and you should know that I respect RAAL products. But they just aren't my cup of tea. I'm not particularly interested in high aspect ratio radiators, be they tweeters or otherwise. I'm actually toying with the idea of placing a circular wave guide on the Neo3 for the next generation Note. We'll see. I'm not ducking your questions but I really don't know what optimum configuration would be. I know what I would like for the response. I guess if I were to try to design a true dipole tweeter is would be very similar to what Rudolf was proposing many posts ago, back to back domes which radiated as a true dipole but for which directionality took over before the on axis nulls appeared.
I also can not tell you how I would design a higher efficiency speaker. It is not something I would comment on off the cuff. But I can tell you I would not be using any type of gradient woofer system. If I wanted high efficiency across the spectrum I think I would pretty choose to suffer loss of accuracy the much go with a ported woofer. After that I just don't know.
Old 3rd January 2011, 11:37 AM   #119
john k...'s Avatar
Originally Posted by Elias View Post
Hello all,
That is the old fashioned engineering point of view but unfortunately it does not make any psychoacoustical sense. What we really need is monotonically widening dispersion somewhere above 3kHz. To minimise the cross talk artefacts of stereo one needs to spatially homogenise the pinna cues and that is most easiest done by providing very wide dispersion at treble, almost omnidirectional above 3kHz.
Also in the midrange below 1kHz one needs to minimise room reflections to be able to provide stereo ITD cues and that is best done with very narrow dispersion.
Clearly it turns out the ideal loudspeaker directivity is not constant, not narrowing but widening!
This radical view was offered for your pleasure by Elias
I respectfully disagree.
Old 3rd January 2011, 11:52 AM   #120
Telstar is offline Telstar  Italy
Have you ever looked at the Rubanoid?
It's veery similar...
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
On the directivity of dipole tweetersHide this!Advertise here!
Dipole tweeters firestorm Multi-Way 19 7th February 2010 01:18 AM
FS: Linaeum/Tandy Dipole Tweeters rabidlistener Swap Meet 3 27th July 2007 10:16 AM
FS: 1 pair of aura / linaeum dipole ribbon tweeters zobsky Swap Meet 9 13th September 2006 09:46 PM
Blending controlled directivity treble with dipole midrange? 454Casull Multi-Way 21 17th September 2005 12:28 AM
Set of 4 Optimus Linaeum Dipole Tweeters on Ebay The Paulinator Swap Meet 1 13th July 2005 06:30 AM
