Will this horn/driver combo beam? - Page 2 - diyAudio
Old 7th May 2010, 07:27 AM   #11
Defo is offline Defo  Norway
Originally Posted by limono View Post
Why not add a tweeter and two more horns ? If you want to use tractrix you need many horns for best results. Otherwise use CD horn and EQ the heck of it.
More crossover points, and less of a point source dispersion, which is things I dont like in my loudspeakers
Wouldnt it work to just use a plug pictured above to reduse beaming?
Old 7th May 2010, 01:06 PM   #12
Paul W is offline Paul W  United States
Paul W's Avatar
Horns are designed to beam. Why not use a horn/waveguide designed to produce the polar pattern you want? What is your objective?
Paul
Old 7th May 2010, 01:11 PM   #13
Because I like the sound of these horns, and I've have yet to find a 400hz cf waveguide. I frequenly see fullrange drivers with large phase plugs to improve dispersion, why not do the same with tractrix/Le Cleach horns? I guess you would have to eq the top end though, to get flat on axis?
Old 8th May 2010, 03:05 PM   #14
Paul W's Avatar
Yes, if you move toward a constant directivity WG, you will need more top end EQ for flat on-axis response...but think about where that additional energy goes. Assuming a phase plug changes polar response, and therefore modifies in-room direct/reflected energy, the result will sound different than the horns you say you like. Better than the horns you like? Worse?
It seems doubtful you can find a phase plug design that won't muck up a tractrix or LeCleach flare. So, IMO, the best solution for you is to pick a proven horn/WG design and buy or build it. If you want to try a CD WG, DDS makes a 24" WG that may approach 400Hz.
Paul
Old 8th May 2010, 03:26 PM   #15
Don't stick a plug in the middle of the horn to get wider directivity. That will just give you more reflections. Instead build a horn or waveguide that gives you the pattern that you want.
Related to your earlier question about LeCleac'h vs tractrix, in some cases at least the LeCleac'h will have wider (lower) directivity at some frequencies. See below:
LeCleac'h 275Hz:
Tractrix 275Hz:
Looking at the -6dB curves, the LC is about +/- 40 degrees at 500hz, about +/-30 at 1kHz, and a bit over +/-20 at 3kHz (a decade about the flair frequency). The tractrix is about +/- 45 degrees at 500hz, +/- 25 at 1kHz, and a bit over +/20 at 3kHz. So the LeCleac'h looks to be narrower at low frequencies and its pattern narrows smoothly as frequency increases while the tractrix goes down to a narrower pattern and then stays more constant as frequency increases. I imagine you could build a LeCleac'h with a faster flair and it would have a wider pattern.
Old 8th May 2010, 06:08 PM   #16
gedlee is offline gedlee  United States
gedlee's Avatar
Precisely. Plugs in horns are a bad idea - only makes things worse.
Earl Geddes Gedlee Website
Old 8th May 2010, 09:08 PM   #17
Could you elaborate a bit please? I dont see why a small shallow plug could be so bad? But I guess the use of them in fullrange apps is a bit different then in horns.
Old 8th May 2010, 09:54 PM   #18
gedlee's Avatar
The plug will be a big diffraction point generating a lot of HOM. Its not the way to improve beaming. A good waveguide is really the only viable way to do this. Thats what makes them so attractive.
Old 9th May 2010, 12:00 AM   #19
djn is offline djn  United States
djn's Avatar
I am not concerned with beaming as I only sit in one position when I listen to music. When I am not "listening" and have the system on, I am doing things around the house and the music is just background. Maybe I am missing something, but if your system is not in a night club or trying to have equal coverage across a wide audiance, then beaming should not be an issue.
Old 9th May 2010, 01:37 AM   #20
R.I.P.
I thought you dumped Tractrix because it was too beamy.
You're not going to get spaciousness with a beamy rendering of the program....
Seas excel and 18sound XT120 horn combo Defo Multi-Way 16 24th November 2012 07:14 PM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
Your Favorite Compression driver & Horn Combo Carl_Huff Multi-Way 15 14th December 2006 11:16 PM
Copyright 1999-2017 diyAudio
