Will this horn/driver combo beam?
Old 9th May 2010, 02:00 AM   #21
Robh3606 is offline Robh3606  United States
Robh3606's Avatar
Maybe I am missing something, but if your system is not in a night club or trying to have equal coverage across a wide audiance, then beaming should not be an issue.
Your power response goes all to hell if you beam so your on axis and reflected sound fields don't match. Not a good thing in my mind. I have both types of systems, one that beams and one that doesn't. The beamer takes the back seat. Definately give which ever horn you are considering a listen if you can.
Rob
"I could be arguing in my spare time"
Old 9th May 2010, 02:15 AM   #22
TrueSound is offline TrueSound  United States
Banned
The 2" driver in the shorter horn will not beam as much as the smaller driver in the longer horn.
Old 9th May 2010, 08:24 AM   #23
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Will this horn/driver combo beam? Will this horn/driver combo beam?
CD-horn (=MantaRay) - is the way to go, if you also want other listeners to enjoy the music in your livingroom...
I tried StereoLab Tractrix-horns...they came off after 2 days. The sweetspot could be measured in millimeters...
Maybe the older 511/811 horns would work too.
Arne K
Don't believe everything you think...
Old 9th May 2010, 08:37 AM   #24
dantheman is offline dantheman  United States
dantheman's Avatar
Here's a cheap PE 10"WG with EQ with the Selenium D220t:
Not too much beaming there, but it's response is rough in a couple spots above 8kHz and there gets to be more reflections in the far off axis graphs. Fortunately out hearing doesn't do so well up there. That graph is 11.25 degrees off center out to 90 degrees in 11.25 degree steps.
Dan
My Blog
My Music Recordings
Old 9th May 2010, 12:49 PM   #25
djn is offline djn  United States
djn's Avatar
Originally Posted by ZilchLab View Post
I thought you dumped Tractrix because it was too beamy.
You're not going to get spaciousness with a beamy rendering of the program....
It was not that they were too beamy, I felt, to my ear, there was a lack of depth and width of sound stage. I'm not very good with these terms and maybe that is what too beamy means.
After hearing Tubino's Yucci's and Dan's new horns I wanted that wider and deeper sound stage.
Old 9th May 2010, 01:02 PM   #26
freddi is offline freddi  United States
freddi's Avatar
hey Dan - not shabby at all for that 10" PE WG - was it on Econowave highpass?
Old 9th May 2010, 02:25 PM   #27
djn's Avatar
I have the 12" PE WG with the Emenance ADS 1001 and it has been my backup horn for years. I have lent it out many times and it always gets great reviews.
Old 9th May 2010, 05:38 PM   #28
dantheman's Avatar
The high pass is a behringer CX3400 (or whatever it's numbers are). It's their active 3 way crossover.
Here's some graphs of that 12"PE WG with the Eminence ASD1001:
on axis:
11.25 off axis:
22.5 off axis:
33.75 off axis:
45 off axis:
The Eminence beams more than the Selenium, but it is considerably cheaper. If wide dispersion is the goal, the Eminence isn't a good option. It seems you weren't too worried about the money.
Good luck, let us know how it goes.
Dan
My Blog
My Music Recordings
Old 9th May 2010, 09:53 PM   #29
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by djn View Post
I am not concerned with beaming as I only sit in one position when I listen to music. When I am not "listening" and have the system on, I am doing things around the house and the music is just background. Maybe I am missing something, but if your system is not in a night club or trying to have equal coverage across a wide audiance, then beaming should not be an issue.
No matter where you sit what you hear is far more than just the direct sound. In fact the direct sound is a small portion of the total sound field that you perceive. The direct sound is critical, make no mistake about it, but just as important are the tembre of the reflections and the reverb field, and these won't be right unless the whole polar response is right.
Earl Geddes Gedlee Website
Old 10th May 2010, 04:26 AM   #30
ScottG is offline ScottG  United States
I'd add that even when the reflections are heavily attenuated, that "direct sound" is far more than simply a single axis.
perspective is everything
Will this horn/driver combo beam?Hide this!Advertise here!
Seas excel and 18sound XT120 horn combo Defo Multi-Way 16 24th November 2012 07:14 PM
adding dome tweeters to altec horn combo ke4mcl Multi-Way 3 28th April 2009 03:34 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
Your Favorite Compression driver & Horn Combo Carl_Huff Multi-Way 15 14th December 2006 11:16 PM
