Old 13th February 2010, 10:45 PM   #1
SunRa is offline SunRa  Romania
Default Altec 515LF modern replacement?
Hello,
This is more of an intelectual curiosity but here it goes.
Do you have in mind any modern replacements (BMS, 18Sound, B&C, AES, that sort of "modern") for Altec 515?
I am interested in low fs (around 25Hz) coupled with high sensitivity (over 98db), and this is usually meaning low moving mass.
The only similar speakers I can think of are Supravox 285 and 400.
Looking for your suggestions!
edit: another hint is that if I'd use this I'd do it in a closed or vented box, not a horn which is the usual application for an Altec.
Thank you!
Old 13th February 2010, 11:21 PM   #2
ScottG is offline ScottG  United States
There are drivers like this.. but are they necessarily more "modern"? Also most are hideously expensive. In addition to most of the Supravox 400 range, there are drivers from GOTO, ALE, AER, etc.. Getting High eff. AND low fs is the problem. Ex.:
Studiobass
Note that even most of these exotic woofers have very low compliance, so they aren't quite the same. Even the more "regular" JBL 2235H (no longer produced) has a low Qm. ..the field coil Supravox 400 with a stronger voltage supply is an exception. Also see:
A515WVL | Great Vintage Loudspeakers
Further - the 515 probably isn't as efficient as 98 db (..prob. more like 97 db). It will likely get its greater db rating from the enclosure - augmented via horn loading or a higher tuning freq. for the bass reflex design.
There is however a "poor man's compromise":
Eminence EMI-1550 15" High Efficiency Sub from Madisound
Get an additional magnet for this thing, positioned (spaced) correctly for added gain - and you should be looking at about 97.5 db.
I should also note that if you increase fs by about 10-14 Hz then your choices will expand quite a bit.
perspective is everything
Old 13th February 2010, 11:41 PM   #3
Inductor's Avatar
Kind of an intellectual response too, look at this contender in pressed steel, maybe not the same.
VOLT Ps15/300
Those AER look nice (they all look nice and w/low Fs), and they are the 4 months well spent, better than the 2 years for the Gurus/Sweden.
Old 14th February 2010, 04:59 AM   #4
Pano is offline Pano  United States
Pano's Avatar
How about the GPA 515. If you want a 515, why not just get one?
Great Plains Audio's LF Loudspeakers
Take the Speaker Voltage Test!
Old 14th February 2010, 05:45 AM   #5
The link is also in his post.
I think it was more a matter of finding a driver that is similar yet better (at least measurably), and if possible: less expensive.
The thing is, no "large" manufacturer wants to produce a driver that requires significant volume to get a decent low-end response. Add to that increased eff.. and well, you are really pushing Hoffman's Iron Law into unreasonable domestic use (..a.k.a "Fridge +" size, and even then for only modest bass extension). Of course the 515 was used in unusual designs (at least by modern standards), but even then most designs were not only large, but still didn't have much bass extension.
Old 14th February 2010, 07:17 AM   #6
Thank you guys for your suggestions.
The Volt and the Eminence drivers linked by Inductor and Scott are indeed new to me, I'll look closer at them. The one from Volt looks great, but that measurement posted there might be misleading, with almost 100g moving mass and 99dB, the woofer might be closer to the typical PA woofers than what I am looking for. The low end rollover is smoother though, which is exactly I am looking for.
Unfortunately, no ALE, GOTO, Kilimanjaro, and not even GPA for me... These are way to expensive to afford them. Not even the Supravox 400. Most probably, if I'll go with the plan to use a woofer similar to the 515 I'd go with Supravox 285GMF which has a relatively decent price.
Exactly yes, that I mean by modern: similar yet maybe better (copper rings, etc ), and also mainstream, which would make it cheap.
However, how Scott already put it,
To give another hint of what I'm thinking of:
This woofer would complement a large midrange (AE15TDM, 18Sound12NDA520, this type of highly efficient stuff), and would run in parallel with the midrange starting at about 80Hz.
The enclosures would be sealed, and I need this second high efficiency woofer to have a reasonable flat response down to 50Hz by summing the two responses.
Think of the inclosures of something like this:Click the image to open in full size.
Old 14th February 2010, 07:38 AM   #7
By the way, look at the T/S of the kilimanjaro series. At 10V in the field-coil you get 99.4dB and have an fs of 24.3 Hz. Why they don't make speakers like this anymore?
Old 14th February 2010, 02:31 PM   #8
Pano's Avatar
Ooops! Sorry. Must not have seen the link against the pale blue background.
The Altec drivers were never cheap, still aren't. Sometimes you can pick up used frames for cheap and have them reconed. Still not bargain basement, tho.
It will be interesting to see what you come up with.
Old 14th February 2010, 03:54 PM   #9
Thanks,
I did some WinISD sims and it's just outrageous, the Altec 416C for example trumps over any 15" up to 21" eighteensound LF woofer at 50Hz in terms of relative gain. I know this is not entirely representative but you've got the point. No matter how you put it, the Altecs are 2-3dB more efficient when used in closed boxes.
Old 14th February 2010, 04:46 PM   #10
There is always someone trying to break Hoffmans Iron Law..
There *is* however a way to "bend" it. Aperiodic with a woofer that is pretty much "unacceptable" by modern standards. The Selenium that Panomaniac uses should work in a smaller volume (..say 4 cubic feet). "Tuning" it to lower it's LF "knee" and also flatten out phase and group delay. Considering room gain and some output from a midbass driver, it might get you closer to what you are looking for.
modern allrange speaker Arnold_R Full Range 5 20th October 2009 03:04 PM
Replacement driver needed for PC spkrs Altec Lansing ACS48, 3" ThatSoundsNice Multi-Way 2 14th November 2008 04:13 PM
Altec 811B horns and Altec 414z 12" Speakers xecluded Swap Meet 0 21st September 2008 05:21 AM
Modern cd's - over compression VanHal Music 113 12th March 2008 10:02 PM
Need help- modern replacement for old trannie DeonC Parts 4 7th March 2008 11:52 AM
Page generated in 0.12807 seconds (74.60% PHP - 25.40% MySQL) with 10 queries
