#32 |
Hi, I just received my WT3 and first I wanted to test some 15" car woofers I had laying around.
The spec sheet that came with the driver says that mms is 126g, so to measure vas I started with adding 100g in the middle of the cone, driver standing horizontal. Now I got the msg that the added weight was to small, so I added more and more....and more, until the added weight was 344g. As you can see in the attached file, WT3 says that this driver has a mms of 392g. I also tried with the driver standing vertical, then mms is measured to 402g. This driver has a very stiff rubber surround, could that throw off the results? Spec sheet says Cms is 217.7 Um/n Im gonna try and make a test box and see if it gives different results. BTW, this is a dual voice coil, and Im measuring both at the same time, connected in series. Last edited by vinnie; 17th May 2010 at 07:17 AM. |
#33 | |
Typically 30 to 100 grams is al you need, but never more than the mass of the original cone. Also, errors for Vas are not uncommon nor represent a big problem in the end. Doing both added mass and closed box Vas testing is a good tact. Just make sure there are no leaks in the box. Even so, leakage past the driver's vent will affect the results slightly. |
#34 | |
I know I had to make sure I set my recording to 2 channel 41K bit but that was it. |
#35 |
Indeed. I remember som DIY'ers in a danish forum, also claiming that manufactur spec's was wrong by a fair margin. But, when a pro-engineer joined the discussion, and giving advice on how to measure correctly, suddenly the DIY'ers came close to the official specs.
#36 |
PCM2900B
TPA6111A2 LMV358 That's all I'm sayin'.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#37 |
Anyone else with a WT3 upgrade to the V2.0 software? It now includes a "rub and buzz" test feature along with LCR measurment functions.
#38 |
I haven't used the "Rub & Buzz" test but I've found the LCR tests very handy to check parallel or series resistors and for unwinding or winding inductors. I think it's good practice to measure components, even if the value is printed on the side.
| Dayton WT3 Woofer Tester available next month! | BHTX | Multi-Way | 14 | 30th October 2007 07:32 PM |
| Dayton Woofer Tester II Anyone try this? | Zero Cool | Multi-Way | 5 | 14th May 2006 01:09 AM |
| Anybody tested the Dayton woofer tester 2 | ostie01 | Multi-Way | 4 | 17th April 2006 03:29 AM |
