Old 9th February 2010, 06:58 PM   #1
Default Building from leftovers, advice on mixing impedances
I want to build myself a nice, mono, self powered monitor for taking to (DJ) gigs where there isn't a nice house system -mostly because I've been sitting on a handful of speakers and I want to build something.
I have:
(1) 1" TB tweeter - 4 Ω
(2) 6" Pyle sealed midranges - 16 Ω each (these suckers have been in their box for 16 years!)
(1) 12" Lanzar 12SE - 4 Ω
Obviously nothing is high grade here, but I really want to use those mids before they turn to dust. I'm planning to wire them in parallel to bring 'em down to 8 Ω and figure the rest out with the crossover. Hopefully I can find a plate amp that will be suitable.
Is it reasonable to run the mids as one channel and bandpass it, and the sub and tweet in series as the other? If so, how could I filter that? Or should I just stuff three smaller amps in the enclosure?
Anyone have any suggestions for my Frankenspeaker?
Old 9th February 2010, 07:43 PM   #2
oh, heh. thanks for the move.
Old 9th February 2010, 08:47 PM   #3
chris661's Avatar
It's fair enough that you want to build something.
Does it have to be a DJ system? I expect those pro drivers would do nicely on an open baffle.
For the crossover - there shouldn't be any problem as long as you remember which driver you're dealing with at the time. Make sure you design an 8ohm XO for the mids, and a 4ohm XO for the bass and tweeter.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 11th February 2010, 10:07 PM   #4
there's a difference between a 4 and 8 ohm crossover?
Old 11th February 2010, 11:25 PM   #5
Moondog55's Avatar
Yes, reactance needs different values .
For inductors halve the impedance halve the coil value but the DCR of the coil has more effect on SPL
For capacitors it is the opposite; halve the impedance double the cap value needed.
Most tables set out a nominal 8R value, better tables give values for 4 / 8 / 16
if your impedance isn't one of the nominal values you have to calculate using the actual impedance at the crossover frequency chosen, which is seldom the nominal value
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 12th February 2010, 06:28 PM   #6
Ah, this must be the vague memory of rectangular and polar number equations from back in school. Time to dig out some old papers!
Building my own TT need some advice jrubins Analogue Source 12 23rd December 2009 09:12 PM
building speakers with components with different impedances ubernova Multi-Way 10 27th December 2008 09:14 PM
New to building, need some advice. msharpe Multi-Way 7 31st January 2006 08:23 PM
a few more leftovers FS cadmaniac Swap Meet 3 29th January 2004 05:43 PM
Riken-Ohm Leftovers Pkg Deal cadmaniac Swap Meet 3 3rd January 2004 02:17 PM
Page generated in 0.08347 seconds (79.64% PHP - 20.36% MySQL) with 10 queries
