i have this amp and this woofer
the amp should have a nominal output power about 35W and the peak power input for the speaker is 200W. i'm afraid, that the big size of the box gives a possibility for the cone to move too far and then the voicecoil could be damaged or something else bad could happen. so is it safe to drive the woofer on maximum power? it rumbles already in half power |
#2 |
Sometimes an underpowered amp can be worse than an overpowered one. If you crank the amp it will probably begin clipping which can damage your driver.
#3 |
Hello KSL,
It looks like yoou Mits amp is 2 channel and your Pyramid sub is single voice coil. The sub says it is rated at 200w in the proper enclosure. Your enclosure looks way big. If the enclosure is way too big you will damage the amp and/or sub. If you hook up only one channel of the amp you can also have problems. Thanks KevinLee |
#4 |
the box is big, indeed, but this size was the ONE. in a 30L box the max dB peak was around 120 Hz
blue color |
#5 |
Banned
i would go and buy a nice cheap 100 watt power amp even if it is a reciever eve if you have to repair it. more power is better than less power. just because the speaker says a certan value (X) doesn't mean that it will either use it all or need it all. you can take a 50 watt speaker and put more than 50 watts into it. depending on box power of amp stabillity and other factors..
#6 |
the thing is, that 35W told the man, who repaired it, maybe it's more powerful? someone can find some specs for the amp MITSUBISHI DA-U530? (i can't find anything)
blue color |
| speaker or crossover damage | evlah | Multi-Way | 9 | 19th March 2008 03:49 PM |
| Jamo Surround 200 Speaker Damage | Jitterbug | Multi-Way | 4 | 2nd May 2006 03:05 PM |
| hafler dh-200 damage? | george a | Solid State | 6 | 10th November 2004 12:29 PM |
| damage the laser? | maya1 | Digital Source | 0 | 16th June 2004 06:09 PM |
| Types of speaker damage,and how to avoid them | Bull | Multi-Way | 18 | 21st January 2003 10:14 PM |
| Page generated in 0.09067 seconds (75.20% PHP - 24.80% MySQL) with 10 queries |
