Old 5th February 2010, 11:17 AM   #1
Default Need help with Focal 7K415 build
hi
I have 4 Focal 7K415 drivers wich I would like to make a 2.5 way or maybe a 3.5 way speaker.
For the mid and treble I have different options. For now Tangband 4W1320 fullrange. Later A small coax. Planning to crossover at 200 - 400 HZ. Using a Hypex 2.100 digital amp/DSP.
Is it possible to go below 35 Hz with these drivers?
First problem is the cabinet type. I would prefere anything else than a bassreflex enclosure.
Maybe a TL or closed cabinet type. I don't know how to calculate a TL and simulations of the closed box shows Fs (-3db) of 80 Hz.
Specs of Focal 7K415
Fd: 32 Hz
Qts: .26
Sd: 163 cm2
Vas 56 l
R 8 ohm
Old 26th June 2011, 08:51 AM   #2
did that project work out ? do you want to sell a pair or the four 7K415 ? Do you know where to get some ?
~e~
Looking For Focal audiom 7k2 or focal 7k6411 jasonyap Multi-Way 0 29th March 2007 06:46 AM
Replacement for Focal 7K415 drivers spraglow Multi-Way 6 17th December 2006 04:43 PM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
MTM design FOCAL 6W4311 AND FOCAL Focal TC120 Tdx2 Bas Horneman Multi-Way 1 5th February 2003 04:21 PM
Page generated in 0.05965 seconds (70.91% PHP - 29.09% MySQL) with 10 queries
