I was able to come up with a range for a panel of height 11 inches using 9mm BB. Worst case (lowest freq.) comes out around 3-5k depending on the Elastic modulus I used. I thought is would be lower than this but maybe it is the correct magnitude.
I agree that your method would be be better but my way may stave off Alzheimers a little longer
