Old 4th February 2010, 10:41 AM   #1
cjcc67 is offline cjcc67  Australia
Default Choosing a flanged port
Fellow DIYers
If you were to build Troels Jazzman ScanSpeak 3- and had a choice of two 70 mm ID flanged ports which would you choose and why:
1) 125mm outside diameter with a deeper flange/ throat made from plastic
2) 105 outside diameter shallower flange and throat plastic flanges cardboard tube.
Is there a likely to be any audible difference?
Old 4th February 2010, 12:50 PM   #2
breez is offline breez  Finland
The one with the both ends flanged/radiused. Reason: symmetrical ports have better distortion performance.
Old 4th February 2010, 09:37 PM   #3
Thanks Breez
Thats a good point. I could use two of the plastic ones back to back could be used for symmetry. I was curious if the internal radius of the throat had any impact. I would guess a more gradual radius would create less turbulence. Whether that is of any consequence ???
Old 4th February 2010, 09:48 PM   #4
Yes, the radius can have an effect. If I remember correctly the radius at the end should be 0.2 times the (inner) diameter (or was it half of that?) of the port for good performance.
It's hard to see from the picture, but do any of the ports have a changing inner diameter? Different kinds of port profiles have a measurable effect on distortion, even at lower levels.
It's a lengthy read, but good stuff for DIYers: http://www.harman.com/EN-US/OurCompa...ions/11094.pdf Lot's of experimental data, good graphs and pictures. The information on the end radius is also found there.
Note in that paper, flanged port means a port with changing inner diameter and radius is what is usually referred to as flanged port around here. Some of the commercially available ports with huge radiuses start to get closer to the profiled ports, especially when the port is short in length.
Old 6th February 2010, 05:47 AM   #5
Brett's Avatar
Lots of port and flaring info here.
Porting at Subwoofer-Builder.com
Need help with choosing port size for Usher 8948A MLTL (folded) sardonx Multi-Way 16 16th July 2011 07:56 PM
Slot port vs circular port equivalence Brisso57 Multi-Way 12 21st February 2009 02:38 PM
Single Port Vent Better than Dual Port? Daveis Multi-Way 18 15th July 2007 05:12 AM
Choosing port diameter. Jeb-D. Multi-Way 8 18th August 2006 06:34 PM
To port or not to port? Newbie with newly built mains starquake Multi-Way 1 18th December 2004 12:51 PM
Page generated in 0.10249 seconds (67.26% PHP - 32.74% MySQL) with 11 queries
