Old 4th February 2010, 01:09 AM   #1
Default OB 12cx DE10 Alpha15a
Okay first pics.
You will notice similarities to a couple of designs. Haven't finished the base plates yet, or taken measurements. But things sound promising. So far no dsp or x-over to the 12cx and a simple 2.0 claritycap to the DE10.
Old 4th February 2010, 01:39 AM   #2
This is the 12cx at 1.0 meter mic directed at cone center
Old 4th February 2010, 02:14 AM   #3
CLS is offline CLS  Taiwan
May I ask the purpose of the 'compression chamber' in front of the woofer? (I also saw this on the products of Emerald Physics.)
Old 4th February 2010, 02:46 AM   #4
with the DE10 and only a ClarityCap 2.0
The Alpha amp is a WF 100k x-over at 100hz
CLS,
As much as I could find out, the volume was approximated by a look at the original product. I took that figure and plugged it into winalpha and played with the volumes. The theory has been put out as sort of a front ported infinite rear volume sub. This in turn increases the power handling. I tried the Alpha on a simple flat mount and two different volume chambers. This seemed to work.
thanks
Old 8th February 2010, 06:59 AM   #5
Looking good. Have you compared the sound of your setup with/without horns. I have similar setup that have Beta 10 and use ME10 horns with the DE10. They sound pretty darn good.
Alpha15a distortion measurements log cuibono Multi-Way 23 17th July 2009 08:05 PM
OB with Alpha15a and SEAS driver AudioGeek Multi-Way 3 21st December 2007 06:45 AM
OB alpha15a with HF tratrix horn questions AudioGeek Multi-Way 2 7th December 2007 01:32 PM
Does Q matter on the Alpha15A and Delta 15A ? ashok Subwoofers 6 5th December 2007 02:00 AM
Beyma 12CX in a MLTL? G Full Range 3 10th February 2007 01:43 PM
Page generated in 0.08262 seconds (73.14% PHP - 26.86% MySQL) with 11 queries
