Old 2nd February 2010, 12:50 PM   #1
Joostp is offline Joostp  Netherlands
Joostp's Avatar
Default Assistance asked with X-over for monitor build with T330-d and 15WU8741
I’m trying to build a monitor with two Dynaudio Esotars T330-D's and two new Scan Speak Illuminator 15WU-8741. This could be a really nice upgrade compared to my Dynaudio Audience 42's (modded).
I also have two Dynaudio 24w100 and two 30w100 lying around but i don't want to use these as the WAF of the enclosure will be to low .
I plan on placing these drivers in a vented 12 liter cabinet build from 22 mm MDF. X-over will probably be something like 2200 Hz. Building a proper cross-over is something I don’t have a lot of experience with and I really need some help to get started. I have specs of both drivers and a drawing of the enclosure attached.
The collective knowledge of all of you could really help me out and i might actually learn something for future projects.
Any help will be greatly appreciated!
Old 3rd February 2010, 01:11 AM   #2
here's an outline of how I'd approach it:
design 2 way crossover - diyAudio
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 3rd February 2010, 10:37 AM   #3
Joostp's Avatar
Thanks, i'm now working down this list and starting with measurements with Arta.
Old 5th February 2010, 07:37 PM   #4
Joostp's Avatar
Unfortunately, after some three hours of trying, i'm stuck and can't get Arta to work with my soundcard. I have signal on output but nothing on the line-in and therefore can't complete calibration.
I'm using windows 7 with onboard Realtek soundchip. Anyone any tips?
Old 5th February 2010, 10:04 PM   #5
Does Windows 7 have a 'mixer' window, like this? You have to select the 'line volume' fader. You also could try the asio4all driver on your soundcard.
Nice drivers BTW!
-Chris
Old 9th February 2010, 11:35 PM   #6
Joostp's Avatar
Thanx Chris, I'll give it a try.
Old 5th March 2010, 08:30 AM   #7
Default mini monitor using illuminator and esotar
Hi i just finished my first diy loudspeaker projects using the same drivers as yours ...
i'll plan to publish the cabinet and final crossover design on the web
soon because i'm still waiting on the illuminator woofer to break in ......
my esotar i got second hand .
so far i'm really satisfied with the result .
my measurement use holmimpulse for individual frequency response .
for combined frequency response and phase i'm using arta .
for impedance , i'm using limp .
share me your email i could send you my temporary cabinet and crossover design schematic .
Old 12th March 2010, 07:35 PM   #8
Joostp's Avatar
Andry thanx for your info.
I build your crossover design today and its less complex than what i was planning on using and sounds way better.
I inserted an 2 db L-pad on the T330 because it was a litte bright for me. I have the same volume cabinet 12.5 liters and i was wondering what the port dimensions of your design are.
Old 7th April 2010, 11:18 PM   #9
Joostp's Avatar
Default Status update
Things are up and running for a few weeks now and i've been busy tinkering with the crossover. I have modified blue andry's crossover and ended up with the one in the pic. There were some problems in the low end but these were solved by adjusting the type and amount of dampingmaterial, i had seriously overstuffed my cabinet and the initial -2 db L-pad was changed to an -7 db(!) L-pad.
So far i have enjoyed listening to them and there should be some improvement with better crossover components and -wiring. I'm not sure what is the best way to position the drivers in the baffle, maybe someone has any hints for a small monitor as this one.
Old 7th April 2010, 11:41 PM   #10
This program provides a great starting point:
Home of the Edge
Suggestions for a Mini-Monitor Build jeffmoore17 Multi-Way 4 30th December 2008 05:07 PM
I am planing to build my first Gainclone and require your assistance... Tripmaster Chip Amps 35 24th March 2008 02:16 PM
Needed assistance to build speaker box. bentley388 Full Range 4 4th August 2007 03:57 AM
Help me build an active monitor for dj'ing lunchmoney Multi-Way 14 6th April 2005 02:50 AM
Esotar T330 clani Multi-Way 0 22nd March 2004 07:35 AM
Page generated in 0.11108 seconds (80.47% PHP - 19.53% MySQL) with 11 queries
