Old 1st February 2010, 06:07 PM   #1
Default Small Tannoy DCs 1666 Parameters
Sorry, but 1st post is a question.
I have a few drivers sitting around and I have found the perameters for the 2008 drivers, but I can't get any information from anyone regarding the 6.5" drivers that I believe are 1666, but may be 2040.
Can anyone help.
I am trying to make use of these drivers in a small enclosure.
Thank you
Old 1st February 2010, 07:28 PM   #2
Pallas is offline Pallas  Pakistan
If you have a Mac, you can measure the T/S parameters yourself with FuzzMeasure and the cheap/simple impedance jig described in FuzzMeasure's manual.
It's always better to take your own measurements rather than trusting others'. Even the manufacturer's.
Old 25th February 2011, 06:18 PM   #3
Default Tannoy DC1666 parameters.
Hi David,
Here are my personal T/S parameters recently measured with Woofertester2 V5.
#1. Tannoy Definition D100 (driver 1666 SN: 468384L)
Re = 4.4522 ohms
Zmax = 33.2435 ohms
Qes = 0.4163
Qms = 2.6921
Qts = 0.3605
Eff = 0.0055
Eff = 89.4378dB @1W
Sens = 91.9830dB @2.83V
Le = 0.3713 mH @1 kHz
Fs = 51.543 Hz
Sd = 0.014103 m²
Vas = 17.862 L
BL = 7.227 N/A
Mms = 0.015 g
Cms = 632.215 uM/N
Kms = 1581.739 N/M
Rms =1.814 ohms
#2. Tannoy Definition D100 (driver 1666 SN: 468387L)
Re = 4.2784 ohms
Zmax = 31.0194 ohms
Qes = 0.4222
Qms = 2.6392
Qts = 0.3640
Eff = 0.0057
Eff = 89.5801dB @1W
Sens = 92.2982dB @2.83V
Le = 0.3754 mH @1 kHz
Fs = 54.045 Hz
Sd = 0.014103 m^2
Vas = 16.239 L
BL = 7.205 N/A
Mms = 0.015 g
Cms = 574.788 uM/N
Kms = 1739.771 N/M
Rms = 1.941 ohms
The D100 is a small cabinet about 10,7 L.
Port dimensions :
diameter = 31 mm
length = 67 mm.
Hope it will help.
Bernard
Thiele - Small parameters tomtt Multi-Way 0 25th March 2009 02:48 AM
Small parameters for a small free-air sub comjunky Car Audio 4 4th December 2007 03:45 PM
Thiele-Small parameters Hoffmeyer Multi-Way 6 15th March 2006 01:12 AM
Thiel Small Parameters? lynkage Multi-Way 17 28th April 2004 07:32 AM
Page generated in 0.07695 seconds (77.90% PHP - 22.10% MySQL) with 10 queries
