How to measure impedance of driver?
Old 30th January 2010, 05:06 PM   #1
lgreen is offline lgreen  United States
lgreen's Avatar
Default How to measure impedance of driver?
How do I get a rough measure the impedance and Freq response of a driver?
I was thinking of putting a 0.1 ohm resistor in series, applying a sine wave (set at 2V pk-pk or something like that) at a known frequency and measure the voltage drop vdrop (pk-pk) across the resistor using a scope. Do this for multiple frequencies.
Current i would = vdrop/.1 ohm
In this case the impedance will = 2(vpk-pk) /i .... right?
I could also measure the magnitude of the output as detected by a microphone to get a rough idea of how the driver behaved across a frequency range. (I know you should account for FR of mic but lets ignore this for now)
Do this for multiple frequencies and plot?
Is this roughly ok or is there a better way?
Retired from DIY (2010) but still lurking now and again. My DIY audio projects- PartTimeProjects.com.
Old 30th January 2010, 05:34 PM   #2
Iain McNeill is offline Iain McNeill  United Kingdom
diyAudio Moderator Emeritus
Iain McNeill's Avatar
You need to use RMS so Vrms = Vpk / 1.414
Current in 0.1ohm resistor will be a very small voltage leading to errors in the impedance. I use a 1ohm resistor myself and this makes it very easy to compute impedance as Z = Vrms(across speaker) / Vrms (across resistor) (which is what your AC voltmeter should be reading)
A good way to proceed is to scan frequencies for the greatest voltage across the speaker first - this is resonance, and then map impedance carefully about this point, expecially to find the frequencies above & below resonance where Impedance = Rmax (at resonance) / Re (DC resistance). Then you can calculate Qts as well.
How to measure impedance of driver?Hide this!Advertise here!
How To Measure Input Impedance Of Solid State Amplifier? kelticwizard Solid State 11 28th January 2006 03:34 PM
How to measure the output impedance of the DAC chip ergo Solid State 2 9th June 2004 07:07 AM
How do I measure OPT impedance? roundel325 Tubes / Valves 1 30th April 2004 07:28 PM
Speaker impedance measure by a newbie jormartr Multi-Way 1 17th October 2003 02:09 PM
How do I calculate (or measure) my amp's output impedance? Saurav Tubes / Valves 22 27th September 2003 03:55 AM
