Hi, I am a beginer in speaker diy commnity and would like to have help from you fellow diyers.
I got a pair of 9" woofers of JBL P941 in-wall speakers and want to mate them with seas H1304 and H1499 for a speaker project. It seems the type of speaker with this 9" woofer should be a closed-box type given the fact P941 is an in-wall type of speaker that is cloest to closed-box. But what's the optimal volume for them? Below is the spec. of JBL P941. General Recommended Power 15W – 200W Nominal Impedance 8 Ohms Sensitivity (2.83V @ 1m) 89dB Frequency Response (-6db) 32Hz – 20kHz Crossover Frequencies 300Hz, 2kHz; 24dB/Octave High-Frequency Transducer 1" Pure-titanium dome Midrange Transducer 3-1/2" Low-Frequency Transducer 9" OCC (Organic Ceramic Composite) Baffle Cast aluminum Port None Network SSP™ (Straight-Line Signal Path™) Grille Material and Finish Gray cloth with metal wire frame Terminals 5-Way, gold-plated binding posts Dimensions (H x W x D) 20-5/8" x 13-9/16" x 3-1/2" (515mm x 345mm x 89mm) Cutout Dimensions (H x W) 19-1/8" x 12-1/2" (486mm x 318mm) Weight 15 lb/7kg |
| Looking for T/S of the JBL M115-8A Woofer | soulshine | Multi-Way | 2 | 20th April 2009 09:08 PM |
| WTB: JBL L128h woofer | Tronhead | Swap Meet | 1 | 17th October 2008 03:00 PM |
| JBL K140 Enclosure Design?? | Max Rockatansky | Multi-Way | 1 | 15th September 2005 12:45 AM |
| JBL 5in woofer | Praudio | Swap Meet | 0 | 8th May 2004 09:35 PM |
| Page generated in 0.06377 seconds (67.17% PHP - 32.83% MySQL) with 10 queries |
