Who can help me about box and crossover for this drivers?I have small room,thinking about small BR with stands...or ML-TLs.Beyma have qts around 0.29...
#2 |
I had Beyma in 7l box. Used in 3.5x3.5m room.
I was not very impressed with this driver. The sound is smooth but without to much details. It is quite "slow"; I would not use it over 2500Hz. Bass is not great either. Easy to implement crossover. It can sound good but only if you use a subwoofer and ~1.8kHz crossover. I would recommend you the Dayton RS150 instead. The price is about the same but you get better bass and more details. You still have to cross it quite low so DTW97 may not be an option. |
#3 |
Thanks!
#4 |
To reinforce what tpsorin said I tested/simulated these 4 drivers: Beyma 5MP60N (black), Dayton RS150-4 6" (green), Dayton RS150S-8 6" (red) and Fane Studio 5FR (yellow). Another good contender it's the Aurum Cantus AC-130F1 5-1/4" Woofer
http://www.parts-express.com/pe/psho...00&ctab=2#Tabs Last edited by Inductor; 31st January 2010 at 02:36 AM. |
#5 |
Problem is that I already have this drivers....
#6 |
probably best used as a mid driver, you won't get much bass below ~50Hz out of this driver
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#7 |
Beyma 5MP60N
It's a good driver. PeteMcK might be very right. You will probably add later a sub or woofer. In the mean time, a BR of about 12L (as in the spec sheet/or a little less) or closed box (less bass) it's possible with the volume I mentioned before in the other post, or similar. Visaton DTW97 Last edited by Inductor; 8th February 2010 at 02:56 AM. |
#8 |
UCan use this xover as a starting point (BR~10L/12L).
#9 |
Very nice from You...I will also try Beymas in a angular spiral horns,enclosure for FE126e...not the same driver,but low qts,low moving mass,small Vas...small box for small room...18x31x30cm...size of the box!!!
| Help with Beyma design | Pooley | Multi-Way | 4 | 29th June 2009 10:56 PM |
| Beyma SB18 | muri | Subwoofers | 4 | 12th May 2009 09:41 AM |
| Beyma CP21/F | Sjef | Multi-Way | 7 | 29th December 2004 07:54 AM |
| "Visaton - is it worth?" or... "Share your Visaton experience" | mr_push_pull | Multi-Way | 10 | 7th August 2004 06:18 PM |
| Has anyone experience with Beyma??? | DarkOne | Multi-Way | 1 | 25th February 2002 12:29 PM |
| Page generated in 0.08918 seconds (79.33% PHP - 20.67% MySQL) with 11 queries |
