Old 30th January 2010, 08:11 AM   #1
Default help what do they do
Ok next question is on the wiring to the tweeter there is 2 components that are soldered in series on a board
20w33r and a 47uf capacitor 250 vac is this like a high pass filter or just basic protection
all help appreciated.....
Old 31st January 2010, 12:39 AM   #2
Francec is offline Francec  Australia
Banned
Is this English? If so, where are the capitals and punctuation?
Common courtesy would dictate proper English when asking for assistance.
Old 31st January 2010, 12:52 AM   #3
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
"next question" would imply that there was a first question.
20W33R would be 20 Watt, 33 Ohm resistor
47uF 250VAC would be 47uF cap, rated to 250 Volts AC.
What they do, well you'd need a schematic for that, all you've listed is two parts with no other information.
The power of Science compels you!
Old 31st January 2010, 04:38 AM   #4
Moondog55's Avatar
Queens English preferred if you are British
Qinz Anglish if Ozzie??
Probably a Zobel but without a schematic it is only a WAG?
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 31st January 2010, 04:58 AM   #5
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
I can tell you exactly what it does: it lets some electrons through but not others.
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 31st January 2010, 07:07 AM   #6
Default From what I see it is
It is looking like it is for the Zobel Impedance stablizer network for the woofer unless there is another cap in series and the resistor in parallel, for 1 cap for 6db is not going to be that high usually up to 8 uf max. So either you are missing a cap before that one and there should be also a coil in parallel for making a third order. And you would not need to use such a high wattage resistor for a tweeter.
Old 31st January 2010, 07:45 AM   #7
chris661's Avatar
Or such a high voltage cap.
I read this as a simple 1st order crossover, but a resistor in series to compensate for efficiency differences between the tweeter and the woofer.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 1st February 2010, 08:29 AM   #8
Ok you guys obviously know your stuff, im trying to learn and a big thanks to the ones that answered me.
The way i described the components is how they are, just a small board 2 components going to tweeter.
Maybe i should've said its a 350wrms 8ohm woofer and a 100w 1000kohm tweeter.
Old 1st February 2010, 08:32 AM   #9
The use of these components does not got to woofer at all, just thought i would let that be known also..
Old 1st February 2010, 02:00 PM   #10
DougL is offline DougL  United States
Neighbor,
A drawing would speak volumes.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Page generated in 0.09407 seconds (84.06% PHP - 15.94% MySQL) with 10 queries
