box design
building my firs ever DIY amp and speakers and cause of that I would like to stick to some checked design.
I need a design for 2 way speaker box with a 25cm bass and about 10cm middle (not sore yet exactly for middle tone one) 4 ohm if it matters some how and one question more is do I need some different middle tone then if I were making a 3-way? |
Look here for a lot of experience and ideas, matching speaker drivers and xovers.
SEAS constructions You mean that if you use a tweeter (*middle tone?) in a 2-Way config. (w. Woofer/Tweeter), that you can use the same tweeter in a 3-Way (Woofer/Mid-Woofer/Tweeter), yes that looks like it. *By middle tone do you mean the mid frequencies or voice band like from a Mid or a Mid-Woofer, 300-2KHz range, (Squawker) or the top/high frequencies 2K-20KHz tweeter (?).:confused: |
By mid I mean the speaker for middle range frequencies like the one on a 3 way.
So to simplify the question: in 3 ways you use bass, mid range speaker and high tone speaker.In 2 way you use bass+mid range or high tone or some speacial for 2 ways? |
laki101
search for a F.A.S.T. projects in FULL Range forum D |
Examples from the designs of others can be quite instructive:
Zaph|Audio DIY Loudspeaker Projects Projects Humble Homemade Hifi |
Here is a place to start if this catches your imagination http://www.diyaudio.com/forums/full-...ions-fast.html dave |
| All times are GMT. The time now is 02:51 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
