The Hi-Fi Answers transmission lines that I have were fairly high end when I built them in the mid 70's. And I have certainly had my money's worth out of them over the years.
However, I am sure designs have moved on somewhat over the last 30 years or so. And they don't seem a good match to my little tube amps (10W max), as they are very underdamped on bass. Bass is fine on SS amps, but the treble is typically harsh. As I have to pull the boxes apart to repair/re-cap the crossovers, I am considering options for a full rebuild. Are there any modern designs that would suit the venerable KEF B139, B100, T27, and Coles 4001G drivers. Or would I be better off just doing the crossover repairs and going for a whole new design/driver combination. Thoughts anyone? Gary |
#2 |
frugal-phile(tm)
Perhaps a bit more radical idea... take the B139 and put them into one of the versions )or a variation) of the modern TL we designed. Transmission Line Speakers
Then sell the B110s, T27, and Coles (maybe keep the Coles as a supertweeter, depending on your FR choice). Get yourself a suitable FR. Do a bi-amped FAST. (a good place to start on that last term). Tubes on the top, SS on the bottom. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Thanks Dave.
I am in the midst of re-capping the crossovers, and having done one cabinet the difference is dramatic. Much happier on the tube amp now, so I guess the caps were a problem. Bass is tighter, and the rest of the range is far clearer. I think I'll keep these as "classics" and look at a ground up build with new drivers. |
| Chris Babineau | Chris Babineau | Forum Problems | 2 | 9th February 2009 05:53 PM |
| Chris Rogers PRO9-TL Drawing | BigYin | Multi-Way | 7 | 20th February 2007 03:03 PM |
| Introducing Mr Chris | Mr Chris | Introductions | 4 | 5th February 2007 03:07 PM |
| Blown Luxman (Chris??) | K-amps | Solid State | 9 | 20th July 2006 08:28 PM |
| PYE HFA 12 (AKA pro-lab 100) internal connections | steve_v | Multi-Way | 0 | 10th December 2004 06:25 AM |
| Page generated in 0.06980 seconds (72.40% PHP - 27.60% MySQL) with 10 queries |
