Old 27th January 2010, 08:14 AM   #1
David Gatti's Avatar
Default Small vs large woofer stresses on enclosures
We all know it's easier to make a small enclosure rigid, but does the greater cone movement of a small woofer impart more stress/resonance on the enclosure than a much larger woofer which only moves 1/2 to 1/3 as much?
Old 27th January 2010, 08:41 AM   #2
Moondog55's Avatar
Good question
How much overpressure are we talking about here??
And I would guess that only applies to airtight boxes
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 27th January 2010, 09:21 AM   #3
No, I'm not talking pressures, I mean the physical reaction of the enclosure to the driver movement.
I'd assume the larger driver has less reactionary force (by virtue of it's lesser cone movement) spread over a much larger mounting area, so it is maybe 4 times less stressful on the baffle. But on the other hand, a larger driver has a much larger hole, weakening the baffle.
Old 27th January 2010, 09:41 AM   #4
SaSi is offline SaSi  Greece
What I am thinking is that the excitement of the enclosure by the woofer isn't a function of cone size or excursion but of BI ("horsepower?").
If you take the driver's size compared to front baffle width into account, then the matter becomes much more complicated. Because you then need to take bracing into account.
Old 27th January 2010, 09:44 AM   #5
Moondog55's Avatar
I would have thought it was a matter of the different masses, heavy cone needs heavier box sort of thing; but I have not thought it through yet, still a very good question; looking forward to the answers you get
Old 27th January 2010, 10:29 AM   #6
infinia is online now infinia  United States
infinia's Avatar
Ive heard of small sub enclosures walking across the floor. and what about using opposing woofer/passive rigs?
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Sub: 1 large or 2 small drivers ? Bigun Subwoofers 52 21st February 2009 10:46 PM
OB with a small fostex and a large woofer Rafal Full Range 44 26th November 2008 01:15 PM
need help building woofer enclosures thatotherguy Multi-Way 14 14th July 2008 03:43 PM
large v small drivers marec Full Range 15 23rd January 2008 08:49 PM
SMALL ENCLOSURES [width] Maak Multi-Way 18 28th May 2003 03:55 AM
Page generated in 0.08541 seconds (74.98% PHP - 25.02% MySQL) with 10 queries
