Old 27th January 2010, 03:06 AM   #1
Default Refoaming Late Goodmans Magnums
Hi i have a pair of late Goodmans Magnum speakers, made sometime in the early 80s in a very nice condition. They have power indicator leds and mid and high l pads on the front. Sadly both of the 12" woofers have suffered from foam rot, goodmans have long gone (unfortunately) and despite looking around the net, i can't find a foam replacement that fits. I was wondering if anybody has refoamed these before, or has any idea where i could locate a suitable surround? I don't want to consign these to the skip over a simple refoam. I'm in the uk.
Many thanks,
Adam
Old 27th January 2010, 03:47 AM   #2
Many thanks,
Adam
I was just looking around on the net for "DIY speaker foam" and found plenty of sites. As far as DIY, I've done 6 Advent drivers, 4 with the masonite rings and 2 with the stamped baskets. The first kit came with new dustcaps and centering shims which I used. Later kits had no shims and I had no issues at all NOT shimming the voice coil. It just takes time for the glue(s) to dry. I removed the masonite rings and cleaned all the old gunk off and used the latex glue for the foam and silicone bathtub caulk to bond the masonite back into the baskets with a whole lot of clothespins around the perimeter until it 'cured'. The original glue for the masonite was contact cement but I don't much care for working with that. It's nice hearing them again as they used to be.
Old 28th January 2010, 12:13 AM   #3
Inductor's Avatar
I like very much doing business here Good Hifi's speaker rings - foam, rubber and fabric for more than 3000 speakers.
Old 7th June 2011, 06:48 AM   #4
Many thanks,
Adam
Hi. I may be able to help you I have some 12" goodman foams- dimensions
OD Lip 305mm / OD BUMP 277mm /ID BUMP 240mm / ID LIP 233mm
Mark
Old 13th July 2011, 02:02 PM   #5
Mark
Hi, that sounds like exactly what I've been looking for - the original poster's description sounds exactly like the boxes I inherited, and the foam dimensions seem just right. Do you still have those?
andy
Refoaming woofers bestbier Multi-Way 5 6th April 2009 03:24 PM
removing old adhesive for a refoaming ichiban Multi-Way 3 7th August 2008 01:49 AM
Questionable Speaker Refoaming JOB vafan Multi-Way 20 31st October 2007 12:17 AM
Help with refoaming oofnik Multi-Way 0 16th July 2007 02:57 AM
Dynaudio refoaming soulfuel Multi-Way 8 24th August 2006 05:31 AM
Page generated in 0.08930 seconds (74.84% PHP - 25.16% MySQL) with 10 queries
