Hi guys
Great forum you have here hopefully this will be a good first post.. Ok ive been looking at a cabinet that im trying to replicate but im struggling to under how the ohms law is working i'll try and explain the cabinet has a 8 ohm impedance the bit i dont understand is the fact that the components are as follows 15" 350wrms driver 8ohms compression driver 8ohm crossover for use with 8ohms now as i understand if you wire 2 x 8 ohm speakers in parallel you make 4 ohms and if you wire in series you would get 16 ohms so how have they come up with a total impedance of 8 ohms is it because the use of the crossover thanks steve |
#2 |
Ok - there's a few reasons, so I'll try to cover them all.
The first is that it's considered 8 ohm nominal impedance. It's a number that's vaguely central to the impedance curve of the speaker. They're usually 4 or 8 ohm, so most will round to the nearest of those two. The second reason is that a crossover is designed so that the drivers don't end up playing the same thing. Because of this, the impedances don't actually interract at all. So, if you have a woofer of 8 ohm, cross it over to a tweeter of 8ohm, they will have no effect on one another. An easier way to think about it - picture 2 amps, on running the woofer, one running the tweeter. They'll each see 8ohm. The problems occur when more than one driver is playing the same frequency range. Putting 2 8ohm woofers in parallel will indeed give 4 ohm. Hope this helps Chris PS - Welcome to the forums.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#3 |
Chris
Thanks for a nice and easy put response i will carry on building now with the crossovers once again thanks |
| ISOBARIC 16 ohms load powered by 8 ohms Amp | eddi0 | Subwoofers | 24 | 21st October 2006 03:29 PM |
| Anyone ever build a glass cabinet? | Javachip | Multi-Way | 14 | 23rd May 2006 03:27 PM |
| will this transformer work for bridge into 4 ohms? | aletheian | Chip Amps | 20 | 4th February 2006 05:04 PM |
| Modifying the Tannoy GRF horn cabinet- will this work? | DeonC | Multi-Way | 9 | 26th August 2005 04:20 PM |
| Page generated in 0.06512 seconds (71.56% PHP - 28.44% MySQL) with 10 queries |
