Old 25th January 2010, 11:07 PM   #1
Default EQ Setting Questions.
Ok i didnt know where else to put this question but i was wondering if anyone knew of a software for free that will do as follows.
-Take a measurement from a microphone.
-Suggest EQ for the room using a 31 band stereo EQ.
-Be able to use multiple measurements before doing above.
-also like i said earlier it HAS to be free.
I want to use this software to set up my EQ for dances and events like that as I now own a DJ company but i dont have tons of money.
Bigger the better... unless you like peace and quiet...
But we can fix that too.
Old 26th January 2010, 03:09 PM   #2
Any of the free measurement software packages out there will let you measure response. You'll have to use your brain to figure out where eq would be useful, but that's pretty easy. Averaging curves is a bit trickier... You could do it yourself in excel, for example, with any software where you could export curves. However that will definitely slow you down.
Realtime RTA: jDFT - the free RTA software for Windows
Holmimpulse: HOLM Acoustics
Speakerworkshop: Speaker Workshop
Old 26th January 2010, 05:54 PM   #3
chris661's Avatar
I'm curious. Why exactly would you wish to do this?
(most) People that will be listening won't particularly care how it sounds, so I think you'd be throwing money at a non-existant problem. Sure, there's always one or two that say "oh - that could sound better", but 1 or 2 in a crowd of 100 isn't anything to worry about.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 26th January 2010, 06:32 PM   #4
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
If you take an on-axis measurement with a mic and EQ it to be flat (or not flat in the case of a dance event), it will only be so on the measurement axis...move your head a few inches to the left and the response is changed...Best solution is to EQ by ear, play some music and walk around the room to see how it sounds in different locations.
I have seen some large venues will play noise through the speakers with mics placed around the room and a spectrum analysis of each mic...then move speakers around to find the optimum location...but this is quite an expensive procedure.
The power of Science compels you!
LCR EQ questions sbear Solid State 1 26th March 2007 02:11 AM
setting and placement questions... maguire Subwoofers 1 5th October 2006 08:54 PM
Setting up EQ manually ackcheng Multi-Way 6 21st April 2004 11:15 PM
Setting up EQ manually ackcheng Digital Source 1 21st April 2004 04:53 PM
Available EQ on combined electronic crossovers/ EQ: Berhinger, dbx, etc rick57 Multi-Way 10 11th June 2003 10:59 PM
Page generated in 0.07984 seconds (72.88% PHP - 27.12% MySQL) with 10 queries
