Hello! G'day Ni Hao Originally i purchased the Technics speakers from the paper for $50, plus $50 to courier to home. Nothing wrong with the drivers so i sold them, for an old speaker the woofer was awesome !!, mid and tweeter, where ok also, but in my quest for better sound and bass ( well Technics woofer had more )The Woofer i purchased was Peerless 830669 SLS woofer. http://www.lautsprechershop.de/pdf/peerless/sls12.pdf I decided to remeasure the inside of my speakers without pressing the ruler into the fill. Height: 83.5cm Width: 33.5cm Back: 33.0cm Tube is 17cm inside box and diameter is 13cm Ports 2 x 6.6cm I am not sure but the 13cm length might be the best out of the box for bass. Crossover, is CYC 22uf 100v for woofer, i have on order Solen 22uf 400V caps. Tweeter and Midrange on crossover has been replaced with Solen 3.3uf 400v and 6.8uf 400V caps. Throughout the box ive used Supra Ply3.4S speaker cable. Fill ( some wool i got from a sale) on back sides top and bottom of box. ![]() ![]()
Technics SVI3206a![]() Philips TDA1541A DAC![]() |
#2 |
If you are happy with the job OK
Most people here would say why bother, the original box is not of the best construction ( needs some serious bracing ) but this is how I got into speaker building myself. What is the midrange?? and tweeter?? Is it the original
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#3 | |
Someday i might get a box done for woofer. It has bracing under the wool Midrange is Vifa P13WG-10-04 Tweeter is Vifa DX25TG05-04
#4 |
![]() Don't use a port with this woofer, it is optimized for a medium size sealed box, just stuff the port with a foam filled sock and fill the cavity with polyfill
#5 | |
rahter a hot one up here about 35c Cool so the box is about right for a sealed enclosure of the woofer... what is polyfill
#6 |
polyester fiber, bust open a pillow and use that fluffy white stuff inside, Jaycar sell BAF ( Bonded Acrylic Fiber ) and Clark Rubber sell something similar, don't be too fussy, I use pink batt fiber glass but use some BAF between the driver back and the glass wool, just in case.
That small magnet P-13 has a nice smooth FR, but I don't have enough experience with it to comment on the XO chosen. 22C here, nice and sunny with a sea breeze, we can't be bothered with a barbie so take-away pizza tonite
#7 | |
I also have Jensens AVX-17, i also put supra cable through the boxes off to listen to them now
#8 |
Gotta love those big classic 3-ways!
I'm sure there's plenty of cheap ways to improve them, like baffle reinforcement, capacitor upgrades etc, but you've made a nice start. |
#9 |
Hello David
I have Solen capacitiors, for the mid and tweeter, have some solens on the way for the woofer, i could reinforce it some more i think
| Has anyone ever modified a X250.5? | mert | Pass Labs | 64 | 19th March 2008 06:23 PM |
| ME2 modified | MJS | Multi-Way | 7 | 20th October 2005 03:41 PM |
| Is Aleph 5 modified like these? | Peleus | Pass Labs | 7 | 7th August 2004 08:56 AM |
| Can This Amp Be Modified??????? | OMNIFEX | Solid State | 4 | 11th April 2003 02:37 AM |
| FINALLY I modified it | hugobross | Solid State | 34 | 2nd August 2002 02:58 PM |
| Page generated in 0.11381 seconds (83.34% PHP - 16.66% MySQL) with 10 queries |
