Old 23rd January 2010, 09:19 PM   #1
JammyBStard's Avatar
Default Vifa
Can anyone help me find a datasheet for the drivers I have? they were taken from a paire of Heybrook HB1's;
They are both Vifa;
Main = M21WG-09 8ohm,
Tweet = D26TF-05 6ohm,
I want to design an enclosure for them but I cant find the data; I've found similar but not exact matches in the Tymphany Archives.
Any help apriciated
Old 24th January 2010, 06:32 AM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
There are some old Vifa driver PDFs here but no exact match.
Vifa PDF
This is the only info I could find on the M21WG-09-08 and would be enough to design an enclosure. You could compare that to a PDF that's close from the above site.
Qts 0.70
Qms 4.9
Qes 0.82
Vas 81 litres
Fs 38Hz
Re 5R6
Le 0.9mH
Xmax 3mm
Z 8R
SPL 90dB
Pe 50W
Sd 231cm²
Bl 5.2
Couldn't find the tweeter but the "F" means a different motor (smaller magnet) to the more common "G" versions.
No longer DIY active
Old 24th January 2010, 09:20 AM   #3
Cheers R, It's a start.
Old 24th January 2010, 11:38 PM   #4
Guy at Pure-sound sorted me out with the Tweeter:
D26TF-05 6ohm
* Fabric Diaphram
* "Butterfly" VC Assembly
* Magnetic Fluid
* Prepared for customised front
* Uncoloured sound
Nominal Impedance 6 Ohm
Nominal Power (IEC 268-5) 90W
Frequency range 3-30kHz
Sensitivity 88dB
Effective Diaphram 7.1 cm2
Voice Coil Resistance 4.6 Ohm
Operating power 6.4W
Voice coil Diameter 26mm
Voice coil Height 1.6mm
Air gap height 2mm
Free air resonance 1500 Hz
Moving Mass 0.27g
Force factor 2.3 Txm
Magnet weight 104g
XO for Vifa PL18WO-08-09 and Vifa XT25TG30-04 MTM knightat83 Multi-Way 6 24th January 2009 08:51 AM
Must sell vifa PL18 $20 Vifa pl tweeters $30 colwaiting Swap Meet 0 20th March 2008 03:53 PM
Vifa P17SJ and Vifa D27TG Large Bookshelf MTM rwo Multi-Way 7 24th February 2008 04:47 PM
FS - 2 x Vifa P17 Woofers, 2 x Vifa D25AG Tweeters Xristo Swap Meet 2 27th November 2005 10:55 PM
Page generated in 0.07115 seconds (72.08% PHP - 27.92% MySQL) with 10 queries
