Old 23rd January 2010, 07:08 PM   #1
Default 7" Driver advise
I am looking to pair either the Seas ER18RNX or the Dayton RS180 in a 2 way MTM configuration with the Seas 27TDFC. I want to make sure that I end up with well articulate midrange and lower mids, not as concerned about low end as I have a sub. Any advice?
Old 23rd January 2010, 08:18 PM   #2
I have both these drivers with the Seas 27TDFC. The Seas ER18RNX is superior to the Dayton RS-180. You will get much better mids with the ER18 but it does cost more.
You can check them out at:
ER18RNX at STARLING
RS180 at MERLIN
Personally, 7" is rather large for a MTM. My preference is 5-1/4". You may want to consider ZA14 instead.
ZA14 at SWIFT
Mike
AmpsLab.com
Old 23rd January 2010, 08:30 PM   #3
How do you mean 7" is too large for MTM? Please explain.
Old 23rd January 2010, 08:45 PM   #4
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
It has already been designed for you!
Seas ER18RNX / 27TDFC MTM
The power of Science compels you!
Old 23rd January 2010, 09:20 PM   #5
To maximize the benefits of a MTM, you want to keep the center to center distance between the woofer and the tweeter to the wave length of your intended crossover.
A larger woofer means this distance is longer. You will now have to cross over at a lower frequency.
In the link posted by DcibeL, note the crossover is set at a very low corner frequency. 1.65kHz at 12dB/oct is demanding a lot from a tweeter. Compression drivers are comfortable from 1kHz to 2kHz. Not tweeters.
AmpsLab.com
Old 24th January 2010, 01:10 AM   #6
DcibeL's Avatar
27TDFC is perfectly happy with this crossover point, as are some other regular dome tweeters.
Old 24th January 2010, 01:16 AM   #7
I thought the Seas tweeter would be ok there. Another point is I think the RS180s would be happier in a larger enclosure as opposed to the Seas 7" looks like it likes a smaller enclosure.
Old 24th January 2010, 02:28 PM   #8
Elbert is offline Elbert  Norway
I would recommend taking a closer look at the new SEAS U18RNX/P.
THE ART OF SOUND PERFECTION BY SEAS - H1571-08 U18RNX/P
The new SEAS kit, "Idunn" provides a good case study of what this driver can do:
THE ART OF SOUND PERFECTION BY SEAS - Idunn
If I hadn't already forked out on a pair of W17CY-001 ,the U18 Would definitively have been my choice as it seems to have a lot of the EXCEL series qualities, but more moderately priced and a very smooth frequency response making it easy to work with.
Old 24th January 2010, 06:19 PM   #9
I'm really thinking of going with the Modulas, good established design less expensive drivers though more expensive x-over, but MT or MTM? I just don't think I would be happy with the output of the MTs....
Need 10" drivers and advise netefx Multi-Way 1 24th July 2007 11:17 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
Seeking advise on sub using a TCsound 12" sub arbourm Subwoofers 3 22nd September 2006 01:43 PM
Fast 6.5" woofer advise claudio Multi-Way 10 3rd April 2002 07:13 PM
Page generated in 0.09872 seconds (81.77% PHP - 18.23% MySQL) with 10 queries
