#21 | |
For example, a 3" "full-range" driver might be referred to as a "mid-tweeter" if used in a large room or if higher volumes are desired. An 8" speaker might be referred to a mid-woofer if it has smooth response above 2K, where a classic tweeter might be able to cross over. Bottom line, we are trying to talk about general design goals using variations of established concepts. Non of these are hard and fast rules. Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
#22 |
The term "mid-tweeter" is not known to me
But I suppose it could be a small fullrange driver "midwoofer vs woofer" A woofer is usually a driver to take care of bass in a 3way, or subs It does not do midrange well A mid-woofer is suited fore bass and mids in a 2way speaker, or as a pure midrange in a 3way Usually 8" and bigger are woofers, 6" and 5" are midwoofers, 4" are midrange drivers only Thats only regarding hifi drivers, and there may be a few exceptions |
#23 | |
frugal-phile(tm)
A mid woofer will reach up to a tweeter. A woofer only needs to reach up to the mid-tweeter. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#24 |
frugal-phile(tm)
#25 |
thank you guys for your answer I think I figured it out now!
| Full Digital / CrossOver / Multi Amplifier integrated | KOON3876 | Class D | 70 | 5th November 2012 12:33 PM |
| Frequency range of the human voice & full range center channel speakers | jwmbro | Multi-Way | 31 | 20th January 2008 03:07 PM |
| Full Range | jered22 | Full Range | 2 | 12th January 2005 11:16 PM |
