Old 23rd January 2010, 01:34 PM   #1
dtm1962 is offline dtm1962  Canada
Default Looking to Accurately unwind larger Jantzen inductors to revised smaller values
Looking to make some existing larger value inductors to a lower inductance (unable to get the smaller values).
I have a Jantzen 0.025 mH 18 gauge inductor that I want to generate a 0.0095 mH value and I don't have the equipment to measure. I could guestimate via resistance (ie about 1/2 of resistance gives 1/3 of the inductance) but with the inductor only having not too many turns already, it will be critical that I am accurate & at the same time this is part of a series notch for a tweeter (aluminum) breakup mode >20Khz. SO it has to be accurate since the Q is very high= narrow peak.
Any help would be appreciated.
Dan
Old 23rd January 2010, 01:42 PM   #2
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Know any friends who are into amateur radio? They might have an LCR meter you could borrow
Jim J.
Old 23rd January 2010, 02:17 PM   #3
Here's some advice from John Krutke ( zaphaudio.com ) that may be helpful:
For unwinding a coil, the important thing to remember is number of turns is not a linear relationship to the inductance. Unwinding a .10 halfway does not equal .05 for example. Go to Lalena's inductor calculator ( Inductor Designer / Calculator ), enter the gauge, spool length and spool inside diameter for both a .10 and a .08 to find the number of turns for each one. Subtract the two and you'll know how many turns to unwind from a .10 to make it a .08. Note that this is very accurate but only works for air coil. Before you start unwinding, you can do a sanity check on the .10 by confirming known numbers like the DCR and outside diameter, with what the Lalena calculator shows up.
Old 23rd January 2010, 10:45 PM   #4
Thanks for the input. I will check the website out as well as possibly buying myself a LCR meter....
Dan
Using many smaller heatsinks instead of two larger ones rtarbell Parts 5 12th September 2008 01:00 PM
unwind toroidal transformer tonitze Chip Amps 4 3rd June 2004 02:35 PM
Unknown inductors values future Parts 1 30th May 2003 02:39 AM
parrellel inductors, values add up? Westrock2000 Multi-Way 9 8th December 2002 06:09 PM
Page generated in 0.07231 seconds (73.63% PHP - 26.37% MySQL) with 10 queries
