Old 23rd January 2010, 11:30 AM   #1
Default Info: old ESS crossover
Hello,
you know what is the cut frequency of the crossover in original ess amt 1 A monitor ?
thanks for any help
Old 23rd January 2010, 05:27 PM   #2
stavros is offline stavros  Greece
I HAVE INFO FOR THE
ESS AMT 1D
Fcross=800 HZ
stavros
Old 24th January 2010, 04:55 PM   #3
Thanks stavros,
I think the AMT 1 A monitor are cut to about 1000, but I want confirmation.
Old 28th January 2010, 05:15 PM   #4
Default old ESS crossover
Ok forno
here some photos from ess amt 1a measures
1.cross schematic
2.cross measuring freq (theoterical=800, measuring=900-1000 hz)
3.imp and phase measurings
4.ess amt-1d info
stavros
Old 31st January 2010, 04:14 PM   #5
ATatum is offline ATatum  United States
Its great to find a place where folks still appreciate the AMTs, and have very helpful information about them.
I am still using a pair of AMT-1bs for my main system speakers, and smaller ESS performances for surround. All I have ever had to do was refoam the AMT-1bs about 10 years ago.
I am setting up system in the basement for exercise distraction with a pair of AMT monitors that had not been used for a while. One of them now has lost the high end, but the AMT seems fine.
I clearly have a crossover problem, so the question is: Should I just troubleshoot the crossover looking for what is likely to be a bad/old cap, or should I just do a cap job on both of them. I figure if one goes, another is getting ready to go somewhere else, but since my AMT1bs are still kicking fine, the cap jobs may be overkill.
Also, does anyone have the schematic for the AMT monitors?
What could go wrong when you pull everything apart?
Any help or suggestions would be greatly appreciated.
Old 5th April 2010, 06:19 PM   #6
Yes, a cap job is in order. I have the AMT Monitor schematic for you.
Old 21st April 2010, 03:02 AM   #7
Thanks, el seven, that is great. It is what I figured would do the trick. Do you have any recommendations on what flavor of the caps would be best?
Old 21st April 2010, 04:57 AM   #8
While on ESS stuff can anyone supply details of x-over for the smaller, single sided version. It was NOT a dipole and ran a bit higher I think. Thanks.
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse.
Old 23rd April 2010, 07:54 AM   #9
Default Jonathan a little info please
Part number from the amt and /or physical dimensions or what speaker system it was out of ??
Old 23rd April 2010, 12:31 PM   #10
CSS/XBL is offline CSS/XBL  Canada
Please note that ESS is back in business and so information, support, spare parts, etc. as well as new product is or will be available.
ESS Speakers
Bob
ESS amt 1 am crossover oylore Planars & Exotics 2 1st February 2011 09:40 PM
Crossover calculations (e.g., ESS Heil AMT) cdfr Full Range 7 26th April 2010 02:13 PM
ESS AMT 1AM - original 12" woofer info FORNO Multi-Way 2 9th March 2010 10:33 PM
ESS Tempest LS-8 tweeter info Marik Planars & Exotics 2 10th September 2006 01:12 PM
Page generated in 0.09929 seconds (78.65% PHP - 21.35% MySQL) with 11 queries
