Old 3rd June 2003, 04:29 AM   #1
Default plastic
i want to use a resin based plastic to make some enclosures... anyone had any experience with this sort of thing? does it sound any good?
Old 3rd June 2003, 09:48 PM   #2
leadbelly's Avatar
Are you talking about casting or fiber layup techniques?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 3rd June 2003, 09:52 PM   #3
just casting a resin into a mould - about 20mm thick
Old 5th June 2003, 03:54 AM   #4
leadbelly's Avatar
Oh, I think you're gonna have to do some hard researching to find info on that, because I haven't run across any DIY stuff like that in my searches. Closest I've seen is the fibreglass cloth-over-cardboard horns.
I think the biggest challenge might very well be just the choice of resin and access you have to it. I would think that the polyester or epoxy resin you could buy in a hardware or marine or autobody store would have too little mass/density to make a floorstander that didn't buzz. If you're *dialed in* for a specialty resin, or a bookshelf speaker, it should be fine.
Old 5th June 2003, 04:11 AM   #5
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
I think it would work a lot better if the resin were "filled" with
sand , lead shot, marble chips etc. First you coat the mold with a layer of special resin only (gelcoat) then when that is set, add the filler and resin. A lot cheaper then all resin, and better damping.
Chopped glass or carbon fiber would make it stronger.
Polyester resin is much cheaper than epoxy. Also might release from the mold better.
Plastic TLs Geoff H Full Range 24 12th November 2006 02:27 AM
Which Plastic Mats J Multi-Way 4 27th January 2005 12:46 PM
bonding rubber to plastic Keith D Everything Else 5 31st August 2003 06:51 AM
Plastic baffles? dc Multi-Way 5 21st April 2002 03:00 AM
Page generated in 0.07969 seconds (73.21% PHP - 26.79% MySQL) with 10 queries
