Old 22nd January 2010, 07:59 PM   #1
udtman is offline udtman  United States
Default Mcm 55-1940
Has anyone had experience with this driver?
I WANT to do a dual woofer tower with these units and have tried at least 4 different "box designer" softwares. They all come up with different volumes, sizes, etc.
What im leaning towards is a dual driver vented system based on the calculators from KBapps.com - Home Page.
If i did everything correctly, they recommend a 3.41365 cu foot enclosure with these dimensions:
Assuming .750 thickness of MDF
H: 29.2
W: 18.1
D: 11.2
1 port at 3in x 1.2 or
2 ports at 3in x 2.7 inches which didnt make sense to me
Driver Parameters:
Poly treated paper cone
Treated foam surround
Stamped steel frame
1.18" voice coil
30oz. vented magnet
Specifications::
Power Capacity: 50W/100W RMS/peak
Sensitivity: 89dB (W/M)
Impedance: 8ohm
Re: 7.6ohm
Le: 1.91mH
Frequency response: 38Hz~3.5KHz
Fs: 43Hz
Qts: 0.44
Qes: 0.48
Qms: 5.0
Vas: 34 (liters)
Xmax: 3.5mm
Dimensions:
Overall frame diameter: 8.19"
Required cutout: 7.32"
Mounting depth: 3.35"
Please give me your ideas and or critiques/recommendations
Thank You....
Mcm 55-3205 Mats J Multi-Way 0 3rd January 2010 05:25 PM
Mcm 55-3870 454Casull Multi-Way 0 22nd December 2009 04:54 PM
Mcm 55-3862 ? mhelin Multi-Way 1 8th November 2008 04:47 PM
Anybody try the new MCM 55-3595? S.Spielbergo Multi-Way 1 20th October 2008 06:48 AM
mcm 55-1870...what to do...what to do... nerd of nerds Full Range 4 9th July 2004 07:56 PM
Page generated in 0.05889 seconds (80.60% PHP - 19.40% MySQL) with 10 queries
