Ikea spherical speakers, first build done. Ikea spherical speakers, first build done. - Page 30 - diyAudio
Old 19th March 2013, 12:36 PM   #291
Goodlagger is offline Goodlagger  Australia
Default Bowls
Picks
Old 19th March 2013, 12:37 PM   #292
Default 6.5
Pick
Old 19th March 2013, 12:38 PM   #293
Default Sorry forgot to manage my attachments
6.5 pick
Old 19th April 2013, 01:55 AM   #294
OllBoll is offline OllBoll  Sweden
Progress!
The extra bits are mounts for my tweeters which will be in a ring around the midrange. Current plan is to cover the whole inside and outside with wool carpet... but might be overkill so perhaps I'll settle for covering only backs of the tweeters on the outside and around the edge of the midrange.
Old 19th April 2013, 05:02 PM   #295
badman is offline badman  United States
Custom Title
badman's Avatar
A double isobaric push push, and my spherical CSS FR125 "Galacticons", made from aluminum "Galaxis Space Scanner" housings from lockheed.
On distortion cancellation- I definitely find it to be massively valuable in subs. John K at music and design did a study on isobaric vs push pull and found that isobaric was severely limited for distortion cancellation based upon the additional compliance between woofers, so clamshells must be made with this volume minimized (or some coupling between cones, I've thought a carefully designed cardboard tube and permanent mountings of the clamshell assembly would work very well here.
I made my clamshells with 1/4" between frames, instead of a normal .75" baffle to minimize the compliance volume.
Isobaric
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 1st June 2013, 06:04 AM   #296
miragem3i is offline miragem3i  China
Fantastic. Original thinking!
Old 6th June 2013, 06:33 AM   #297
Studio Au is offline Studio Au  United Kingdom
Has someone commercialised them?
Kugel 871C - Lautsprechershop von blue planet acoustic
Old 6th June 2013, 10:59 AM   #298
vrun is offline vrun  Germany
not really...
BPA or Blue Planet Acoustics is the Distributor of Tang Band speakers.
BPA has a "kit distribution" branch called "OAudio"
Here oadudio is selling their: "Tang Band W3-871OEM chassis"
for a speaker developed by a German Speaker Mag called HOBBY HiFi
HOBBY HiFi 4/2008 is actually older than this thread
The "oa"-Kit consists of 2 Parts:
(1) Their W3-871OEM
_and_
2 "half" bowls "Blanda Matt available at IKEA"
go figure...
Let me have "heatsinks" about me that are fat.
Old 7th July 2013, 02:02 PM   #299
stoomeister is offline stoomeister  United Arab Emirates
Guys,
What about combining Ikea's 28cm bowl with 28 lamp cover (of course damped from inside say by bitumen pads used in car installations) which together will form smth very similar to midrande enclosure of B&W Diamonds 801/802. This enclosure can be sealed ported or aperiodic - depending what works better.
Someone tried it? I'm probably going to, as much as I love my open baffles - having to maintain >1m from the back wall doesnt really work for my living room, and placing OBs closer causes smeared imaging and details.
Any thoughts and suggestions on the subject welcome!
Old 7th July 2013, 02:57 PM   #300
this is a link to lamp:
MELODI Pendant lamp - IKEA
can be also extended into a tapering tube..
Ikea spherical speakers, first build done.Hide this!Advertise here!
Spherical speakers and all that jazz cirrus18 Multi-Way 59 6th March 2009 04:31 PM
Ikea project ceebmoj Full Range 7 5th June 2008 02:14 AM
Spherical Speakers Ironhead Full Range 15 22nd December 2007 03:42 PM
hay ikea boy :) karma Everything Else 7 4th August 2003 12:02 AM
Copyright ©1999-2017 diyAudio
