Ikea spherical speakers, first build done.
Old 21st January 2010, 03:08 PM   #11
Vix is offline Vix  Yugoslavia
Vix's Avatar
Old 21st January 2010, 03:22 PM   #12
Studio Au is offline Studio Au  United Kingdom
Thanks.
human.bin, they were new drivers, I used an old Eltax Monitor 3 speakers crossover just to make sure the drivers actually worked.
I considered full range, but would have had to spent quite a bit more on drivers to get something capable of full frequency response.
For anyone interested the smaller 20cm bowl is 4.1L without any cutouts. vs 9.1L for the 28cm diameter version i used.
Could easily be suspended from the ceiling. I also thought about using a sonotube and a 10" woofer to fire up at the sphere for true omni directional bass.
At some point I plan to build a B&W 800D style 12" or 15" woofer cabinet for them to sit in, complete with granite plinth, (engineering granite tables can be had cheap on eBay), along with some Open Baffle speakers, and some horn loaded speakers and ...........
Old 21st January 2010, 03:29 PM   #13
Key is offline Key  United States
That would be cool. You could use extended bolts or something to put the sphere above the woofer. I always thought it would be cool looking though if somehow (maybe a driver with a large VC) you could fashion a phase plug that doubles as a suspension for a driver above it.
Old 21st January 2010, 03:49 PM   #14
barackuda is offline barackuda  Slovakia
barackuda's Avatar
Just an idea:
How about using them with Jordan JX92S ? They need 8L volume according to their plans.... port 3cm x 11cm (could be challenging)
Old 21st January 2010, 03:53 PM   #15
human.bin is offline human.bin  Italy
or maybe something like alpair7 sealed and the omnidirectional woofer like linkwitz plutos... how would behave the bass driver seeing a sphere over itself?
anyway stunning looking speakers indeed, congrats
Old 21st January 2010, 04:40 PM   #16
link to the Jordans, UK site Wilmslow Audio.: https://www.wilmslow-audio.co.uk/cat...a8814184b73ffd
Old 21st January 2010, 04:50 PM   #17
Iain McNeill is offline Iain McNeill  United Kingdom
diyAudio Moderator Emeritus
Iain McNeill's Avatar
Very nicely done.
but how did you find the center to be able to scribe the cut line? Looks too good to be measured with a ruler. (or at least if I measured with a ruler it wouldn't be that good)
Old 21st January 2010, 04:53 PM   #18
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
that looks like a simpler build than some of the Ikea flatpacks ive built!!! And THAT is a compliment! Might well have to try the smaller ones with some lazy 4" Audax i have lying around...
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 21st January 2010, 04:57 PM   #19
Godzilla is offline Godzilla  United States
Godzilla's Avatar
LOL! Yes, great looking speaker! Love the look!
Godzilla
Old 21st January 2010, 05:02 PM   #20
Iain, wasn't that hard.
I drew out the bowl full scale with the driver hole (picture before the sash cramp).
Then with calipers measured to the outer edge.
The bowls have a 3" flat base, measured the central point and using compass drew the cut line.
Ikea spherical speakers, first build done.Hide this!Advertise here!
Spherical speakers and all that jazz cirrus18 Multi-Way 59 6th March 2009 04:31 PM
Ikea project ceebmoj Full Range 7 5th June 2008 02:14 AM
Spherical Speakers Ironhead Full Range 15 22nd December 2007 03:42 PM
hay ikea boy :) karma Everything Else 7 4th August 2003 12:02 AM
Copyright ©1999-2017 diyAudio
