Large 3-ways design / build - Page 2 - diyAudio
View Poll Results: Will MJL21193's crazy design work as proposed?
Yes 57 51.35%
No 7 6.31%
Maybe. 34 30.63%
I'll laugh when it doesn't. 13 11.71%
Voters: 111. You may not vote on this poll
Old 19th January 2010, 10:37 PM   #11
lowpoke is offline lowpoke  Australia
Send a message via Skype™ to lowpoke
John you look like you know what you're doing. I don't see why people are doubting your curved panel technique. I'm looking forward to seeing the completed project!
Show us what ya got at Homebuilt Hi-fi
Old 19th January 2010, 10:44 PM   #12
MJL21193's Avatar
Thank you for the vote of confidence Jason
It's true that I do have some idea what Im doing but I have been wrong in the past about "sure" things. Like I said: we will see how it turns out. I'll do some accelerometer readings on the panel movement when they are assembled. Worse comes to worst I'm out a few hours work and maybe 30 bux worth of material - I could start again with good ole reliable MDF 4" thick.
Old 19th January 2010, 10:47 PM   #13
SunRa is offline SunRa  Romania
At least the experiment will be interesting . I remember seeing a cabinet design for large phy-hp fullranges which adhered to a lesser degree of stiffness of the walls. Also Nelson Pass 4way with PHY pro drivers has somehow similar principles.
So good luck with this!
Old 19th January 2010, 10:53 PM   #14
Andrew's idea of filling the void with sand sounds like an easy option to try if needs be. (Don't fancy trying to lift them afterward though!)
Old 19th January 2010, 10:58 PM   #15
MJL21193's Avatar
I think it will be too. Thanks
Yes, I want these to be relatively lightweight and filling them with sand would not be a direction I'd think about taking. Also the voids will already be full of foam so I'm keeping my fingers crossed.
Old 19th January 2010, 11:00 PM   #16
I like the innovative approach to panel construction - hope it works well
cheers
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 19th January 2010, 11:02 PM   #17
frugal-phile(tm)
planet10's Avatar
John,
I think this technique has good potential... the concept is something that hasn't escaped me in the past.
Might take some trial & error to get the tension right, and you do want to worry about the long-term stiffness of the panels -- for instance, i expect MDF would tend to become naturally relax over time.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th January 2010, 11:16 PM   #18
Hey John. I made a mistake one time trying to build a 20" bass drum from 5-ply maple Keller shells. The shells were high quality but no matter what heads I used the drum sounded like paper. A dirt cheap mass produced basswood bass drum (with shells almost 3 times as thick) were able to kick it's butt in dynamic range and, most embarassingly, tone. I think I understand where you'd like this design to go but I think you will need more material, and unfortunately, mass. There will be flexure and resonance no matter what the construction. More mass and high damping means lower frequency, lower Q resonances.
On the bright side the way you intend to construct could actually help. You don't have a pure tensile load with cabinet pressure modulation unless the panel is a true arc segment. With one divider and converging edges you'd have a funny curve that would probably change with some more non-linear response. That would be good, but I think considerable problems will come from higher order responses and partially longitudinal waves in a hard thin medium.
Old 19th January 2010, 11:17 PM   #19
MJL21193's Avatar
cheers
Thanks Pete
Originally Posted by planet10 View Post
John,
Thanks Dave,
I want to give this every opportunity to succeed, therefore I'll proceed on the premise the it will work as expected. Filling the voids between the skins with medium density foam will go a long way to locking the structure into a permanent shape. Using a steel "backbone" will (hopefully) address the one potential weakness.
In any case, I'll start soon by cutting all of the parts for the panels. I'll see if there is a local source of the urethane foam I want to use and I'll look through my garage for the steel.
Should be barrels 'o fun.
Old 19th January 2010, 11:37 PM   #20
MJL21193's Avatar
Hi Andrew,
Each box will have some considerable mass - there is the equivalent of more than 2 full 4' x 8' sheets of 1/4" hardboard involved plus whatever I decide to use for the baffle. Probably a few pounds of foam too. Also the skins are not as thin and frail as you think - 1/4" hardboard is very strong and tough.
I don't see enough internal pressure to be able to change the curvature of the skin, especially once it has been reinforced with foam. If the curve does not change shape, it must transfer all of the load to the rigid edges. A structure like this (shallow arch) will not do well with a point load but it will work well with distributed loads (what we find inside a speaker).
Maybe it sounds like I'm trying to convince myself as much as anyone else...
How to build large round front horns? Studio Au Multi-Way 77 27th August 2013 12:14 PM
I'm hooked on large coax, now to build a pair. johnsonad Multi-Way 52 13th February 2009 12:16 AM
Best choices for a 3 ways design. beppe61 Multi-Way 19 25th January 2006 12:44 PM
Thinking up different ways to cover a very large box elambert Subwoofers 15 27th August 2005 02:51 PM
Copyright 1999-2017 diyAudio
