I plugged some driver parameters into an online enclosure calculator. Just want someone who knows enclosure calcs to double check for me. I am a great woodworker, but I totally suck at math.
Does this work out correctly? Driver: Fs: 24.0000 Hz (Free air resonance) Vas: 2.6486 ft^3 (Compliance volume) Qts: 0.2190 Total Q Qms: 1.3000 Mechanical Q Qes: 0.2640 Electrical Q Sd: 0.0130 M^2 (Piston area) Xmax: 3.1800 mm (Cone excursion, linear) Revc: 6.5000 ohms (DC resistance) Znom: 8.0000 ohms (Nominal impedance) Pmax: 35.0000 watts maximum rated power Closed box results: Vas = 2.65 ft^3 fs = 24 Hz Qts = 0.219 Qtc = 0.707 Vb = 0.28 ft^3 f3 = 77.49 Hz fb = 77.48 Hz Also, for using a pair in a single enclosure, do I just double the box volume? Thanks |
#2 | |
You are right, doubling drivers in a closed box, doubles the volume. Some verifying calculations: b |
#3 |
Unibox gives me a Qtc of .251 for 2.65 cu ft, an f3 of 71 and an fb of 95.5 for .28 cu ft;
yes, you double the box vol for 2 drivers. are you using these as mids? if so, a sealed box of ~ 9L (.32 cu ft) looks good for 2 drivers for a Qtc of ~ .707
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#4 |
Cheers. Yes, these will be used with a subwoofer and crossed over around 80hz
| Checking capacitors | Tripmaster | Everything Else | 22 | 11th January 2010 03:41 AM |
| Greetings - New Member Checking In | Moke | Introductions | 1 | 6th August 2008 01:51 PM |
| Help please checking my B+ design | gary h | Tubes / Valves | 26 | 17th July 2008 01:49 AM |
| Checking in... | ghudnub | Introductions | 1 | 19th September 2005 03:58 PM |
| Checking used capacitor | chris ma | Everything Else | 7 | 24th June 2003 12:59 AM |
| Page generated in 0.19902 seconds (56.83% PHP - 43.17% MySQL) with 11 queries |
