Old 18th January 2010, 12:30 PM   #1
David Gatti's Avatar
Default My Apollo project underway
Well its been fairly quiet around here so I thought I spice things up a bit.
This is my 4-way Apollo project which I'm about to begin construction on.
Because I hate to use bass management (routing bass to a subwoofer), these will be full range (-3dB@25Hz), using bi-amping & EQ on the bass driver.
Drivers will be -:
Tweeter - Seas T29MF001 E0047 Magnum .
Details
Midrange - Scanspeak 12MU/4731T00
Details
Bass-mid - Scanspeak 18WU8741T00
Details
Woofer - Seas L26ROY
Details
Here are a few sketches. Overall dimensions will be 52cm x 125cm x 30cm (whd)
I'm guessing this will take about 3-4 months depending on the weather and my workload.
Stay tuned for updates !
Old 18th January 2010, 12:45 PM   #2
StigErik's Avatar
Looks nice! What are the planned XO points?
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 18th January 2010, 12:52 PM   #3
At this stage I'm aiming for 150Hz, 800Hz, & 3kHz.
Old 18th January 2010, 12:54 PM   #4
Looks very interesting!
Don't forget the pictures
Old 18th January 2010, 12:55 PM   #5
StigErik's Avatar
May I suggest placing the lower mid driver much closer to the floor to avoid the typical 300 Hz floor bounce?
Old 18th January 2010, 01:07 PM   #6
Actually, as I prefer 1st order filters, I think its best to opt for tight spacing.
The preliminary simulations I've done show the floor bounce isn't too problematic, with the big Seas woofer filling in the floor bounce and baffle-step losses.
Old 18th January 2010, 01:12 PM   #7
StigErik's Avatar
You should build a simple protoype and measure it.
What software do you use that can simulate in-room response including early reflections?
I think your simulation is a bit optimistic also, considering that your woofer has only 80 dB sensitivity in 4pi.
Old 18th January 2010, 01:22 PM   #8
I'm using LspCAD.
Keep in mind the woofer is actively driven, and will have EQ.
I've done previous designs of a similar nature, so I know what to expect in regards to room effects, mainly a dip around 150Hz.
I guess it's similar in concept to a Vandersteen 5a .
Old 18th January 2010, 01:28 PM   #9
StigErik's Avatar
Ah.. then its no problem, you can just boost it a little bit
I like those angled edges, they keep diffraction under control.
Will the top and bottom boxes be isolated from each other, or will they have close contact?
Old 18th January 2010, 09:26 PM   #10
Isolation - some felt maybe. Any suggestions?
New project underway: Fostex and Pyle Pro Fast1one Full Range 37 28th July 2010 04:04 PM
BLH for the FE 206ES-R- Project Underway graykeene Full Range 19 5th July 2007 04:55 PM
Page generated in 0.10500 seconds (78.35% PHP - 21.65% MySQL) with 10 queries
