Old 17th January 2010, 09:40 PM   #1
Default Cabinet bracing idea
...Moved from a different thread.
I am putting together some mini monitor cabinets. I am "relocating" some drivers that currently reside in some 3/8 particle board cabinets. Needless to say mine will be a bit more rigid... However, in an effort to keep the cabinets small I don't want to add too many braces that will take up too much volume. I will have a couple regardless.
What I was thinking about was building a ladder type structure on the side walls. A drawing would make this easier to understand. The idea is to attach to the walls some 3/4 x 3/4 ply in lengths and a few to span the space between them. Think of the letter H with a few more sections. This would add a lot of stiffness (The ply is turned on edge and is much stiffer this way.) divide the panel in many more sections (raise the resonance up even higher) and not take up nearly the cabinet volume.
Ok now tell me that everyone has already done this once
Old 17th January 2010, 10:15 PM   #2
Moondog55's Avatar
If you are describing what I think you are, yes you're right, it has been done before
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 17th January 2010, 10:42 PM   #3
rcw is offline rcw  Australia
A thing I have used is u section aluminium extrusion, 25x25mm. 3mm. thick.
Epoxied and screwed to the walls this is a brace that is around eight to ten times stiffer than any wooden one and really does effectively break the panels up into smaller ones.
rcw.
Old 18th January 2010, 02:52 AM   #4
I am not surprised it has been done but a little surprised that it is not done more. I will try routing out a 4 grooves in each panel and gluing in a support. That would make for 9 smaller panels. Basically free so its worth a try.
Old 18th January 2010, 04:44 AM   #5
Moondog55's Avatar
Free is good, just make them all unequal
Old 18th January 2010, 02:24 PM   #6
Thats the plan.
Old 19th January 2010, 06:40 AM   #7
Borat is offline Borat  United States
Banned
i don't see anything original or particularly effective about this.
the most volume and material efficient way to build a cabinet is to CURVE the panel as here:
Revel Salon2 - Product Information
and here:
800 Series Diamond | Bowers & Wilkins Speakers
this eliminates the need for bracing completely as well as maximizes internal volume and minimizes material use all at the same time.
when you invent something smarter than that - let me know
Old 19th January 2010, 12:39 PM   #8
Borat- not everyone has infinite wisdom such as yourself.
I never said it was original. I only asked it it looked liked it would be effective. I think that it will be very effective and a lot easier for me to construct with simple tools.
Old 19th January 2010, 01:41 PM   #9
MJL21193's Avatar
Easier and more effective is to cut this brace from a full panel:
which goes from side to side, top to bottom.
Old 19th January 2010, 01:50 PM   #10
Speakerholic
Cal Weldon's Avatar
More effective? Yes. Free? Probably not. Free is good.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
0.50 ft3 Cabinet bracing DIFORCE Multi-Way 3 17th January 2010 07:09 AM
Cabinet bracing for Rabbitz Vifa P13 / D27 speaker gaust Multi-Way 1 11th June 2009 02:31 PM
Bracing the cabinet Lewis Moon Multi-Way 5 4th October 2008 11:54 PM
Metal Bracing in PE Sub Cabinet randytsuch Subwoofers 11 26th October 2007 07:43 PM
When does cabinet bracing become necessary? mazeroth Multi-Way 9 4th December 2004 03:43 PM
Page generated in 0.10939 seconds (80.65% PHP - 19.35% MySQL) with 11 queries
