If I want to model an existing DIY speaker cabinet that someone else has made (with an eye to making it better) what software would you sugest; Ive used WinISD in the past to model a Bass box for the car, but I don't think WinISD lets you model multiple drivers in the same box.
What do people use? |
#2 |
There might be some help here:
FRD Consortium tools guide But perhaps you could elaborate on what you mean by making the existing cabinet better.
Soft Dome |
#3 |
SPEAK - GedLee LLC - will do that. And its free. Just not supported.
#4 | |
They do sound great and the drivers are in excellent condition but the bass is a little bit vague and could do with been tighter. I susspect these drivers could work better in a smaller cab so I was thinking of adding a bracing shelf to the cabs to effectivly reduce the size of the box. I was hoping using some modeling software could help me workout the optimum box size, and perhaps the crossover could do with a tweek. The cabs are 53L, 627x235x360mm (HxWxD) Made of 12mm laminated Ply, no vents louvered baffle. The drivers are both Vifa; Main = M21WG-09 8ohm, Tweet = D26TF-05 6ohm, the X-Over is from the HB1. Last edited by JammyBStard; 18th January 2010 at 08:58 AM. |
#5 |
Try Unibox then.
Remember that enclosures must be designed for the specific application - drivers, etc., and that guessing as to the reduced size is a shot in the dark. Determine the optimum volume with the software and then add wood to the interior of the enclosure per the results.
Soft Dome |
| Acoustic Modeling Software | HK26147 | Multi-Way | 0 | 24th November 2008 11:53 AM |
| HELP with Box Modeling Software | 69stingray | Multi-Way | 5 | 1st January 2006 04:40 PM |
| Modeling software, no soundcards/mics | Bill Fitzpatrick | Multi-Way | 7 | 27th February 2005 03:57 PM |
| Need help with Modeling Software | Wright | Multi-Way | 26 | 17th November 2003 01:23 PM |
| Speaker modeling software | ogp | Multi-Way | 5 | 26th September 2001 07:36 PM |
| Page generated in 0.08309 seconds (76.08% PHP - 23.92% MySQL) with 10 queries |
