diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   B&C 8PE21 or 18sound 6ND410 - What to choose? (http://www.diyaudio.com/forums/multi-way/158828-8pe21-18sound-6nd410-choose.html)
Defo 17th January 2010 02:26 AM
I'm looking for a small high efficiency midrange to be crossed over to the B&C DE10. Both the midrange and the DE10 will have their own wooden mdf waveguide. I allready have a pair of B&C 8PE21 at hand, but im uncertain if its the best alternative for my application. Ive also considered Fostex FE126E. My most important criteria is:
- No fatique!
- Good dynamics
- Easiest crossover possible. (it will be active between bass and midrange)
Do someone have experience with these two drivers, or any opinions?
Thanks. :)
Defo 17th January 2010 09:35 PM
Bump :)
Brett 18th January 2010 09:15 AM
The likelihood of you finding someone here who has compared/measured two different size Pro drivers is rare, because most 'philes are scared of them and stick to only the brand names they know. But here are two sets of measurements by different people, so make of that what you will, as well as a couple of others.
6ND410
8PS21 - not quite the same, but should give you some idea.
8ndl51
8NMB420/
Augerpro's Photobucket = maybe some others in here you might find of interest.
Now, make a decision and build something.
Defo 18th January 2010 07:08 PM
Originally Posted by Brett (http://www.diyaudio.com/forums/multi-way/158828-8pe21-18sound-6nd410-choose-post2051891.html#post2051891)
6ND410
8ndl51
8NMB420/
Thanks for the great reply! :)
But.... Is there ANY 4-8 inch high efficiency midranges that DONT have severe breakup in the upper region? :(
Maybe the driver im looking for dont exist...
Defo 19th January 2010 03:43 AM
Does anyone have any measurements of the B&C 8PE21 please? :o
Brett 19th January 2010 04:18 AM
Originally Posted by Defo (http://www.diyaudio.com/forums/multi-way/158828-8pe21-18sound-6nd410-choose-post2052501.html#post2052501)
What range?
Defo 19th January 2010 10:57 AM
Originally Posted by Brett (http://www.diyaudio.com/forums/multi-way/158828-8pe21-18sound-6nd410-choose-post2053128.html#post2053128)
What range?
300-2khz or higher
sumacSK 19th January 2010 12:07 PM
http://www.prodance.cz/protokoly/8pe21.pdf
8pe21 measurement
Defo 19th January 2010 02:07 PM
Originally Posted by sumacSK (http://www.diyaudio.com/forums/multi-way/158828-8pe21-18sound-6nd410-choose-post2053434.html#post2053434)
Cheers :) You dont happen to have a distortion graph too? To see if the 3khz breakup affects harmonic distortion.
sumacSK 28th January 2010 08:59 AM
Originally Posted by Defo (http://www.diyaudio.com/forums/multi-way/158828-8pe21-18sound-6nd410-choose-post2053530.html#post2053530)
i'm sorry, i dont.. :(
Resources saved on this page: MySQL 18.75%
