Old 16th January 2010, 11:19 PM   #1
Borat is offline Borat  United States
Banned
Default Digital Directivity Control ( more Borat insanity )
consider a coaxial driver where both inner and outer drivers cover the same frequency range.
outer driver beams more. inner driver beams less.
by gradually switching the signal as follows:
outer driver > both > inner driver
radiation pattern can be widened. but it doesn't stop there ! radiation pattern can be made WIDER STILL than that of the inner driver.
for that we mix in-phase signal from inner driver with attenuated out-of-phase signal from outer driver. this produces significant cancellation on-axis but insignificant cancellation off-axis thereby further widening coverage angle.
this angle can be dialed in separately for every frequency. with both drivers on their own DSP processors a more or less constant directivity behavior can be achieved.
this has been another brilliant idea from Borat. thank you very much.
Digital Volme Control elnino86 Parts 27 28th April 2009 05:27 PM
Digital volume control day1118 Digital Line Level 8 21st November 2008 08:11 PM
Digital Volume Control day1118 Solid State 27 19th November 2008 07:42 PM
Digital volume control DJ_Looly Digital Source 17 2nd July 2005 02:58 PM
Digital volume control Eccu Digital Source 2 14th April 2002 12:26 PM
Page generated in 0.06439 seconds (66.02% PHP - 33.98% MySQL) with 10 queries
