Symmetrical crossover
Old 1st June 2003, 05:27 PM   #11
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
Some crazy beer drinking Belgian.
Eric / - crazy beer drinking Aussie.
I believe not to believe in any fixed belief system.
Old 1st June 2003, 06:01 PM   #12
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default Coucou,c'est Moi...
A Belgian that doesn't drink beer is like a Frenchmen not drinking wine.
Now regarding putting your x-over components in either + or - side of the speakers....that's really been awhile ago.
While I do recall having posted something along these lines, I can't quite recall in what particular context.
It has been done before by some more esoteric LS manufacturers, can't quite remember why though. (Beer does that to me. )
Now as far as the symmetric x-over arrangement is concerned, yes, it's a very good idea if it weren't for the extra cost.
Tell me if I'm wrong, but there's no symmetry in a RLC filter
You're absolutely correct of course.
Frank
Old 1st June 2003, 07:17 PM   #13
grataku is offline grataku  United States
What does "components placed of the neutral line" mean?
We are steaming ahead and entering crockland . This is not rf, and even if it was, the most important element IMO would be the homogeneity of the transducer coil and the standing wave behavior. The rf engineers may want to step in here and lecture me on the subject which I am really curious about.
If you are so worried about symmetry use a balanced output amp.
Old 1st June 2003, 07:21 PM   #14
you can put them in any order, it still works the same
RLC=RCL=CLR=CRL=LRC=LCR
You said it yourself, symmetry or not symmetry it's exactly the same.
By your rationale you could cancel out whatever effect of the notch asymmetry by having two parallel notches RLC and CLR of appropriate value
Old 1st June 2003, 09:32 PM   #15
fdegrove's Avatar
Instead of wiring series components on the + side you wire them on the minus.
Send and return if you like.
Personally, I've never tried this out, but assuming you have correct polarity on all you records ( I wish you luck) , I assume it's worth a try to move the filter components to the return lead.
Frank
Symmetrical crossoverHide this!Advertise here!
symmetrical supply PLH amp umut1001 Pass Labs 5 2nd April 2008 03:03 AM
Symmetrical differential vs symmetrical non-differential VAS suzyj Solid State 30 21st August 2007 03:44 AM
70V 5A symmetrical PSU HELP :D firefart_1st Power Supplies 4 20th July 2007 07:59 AM
From symmetrical to N-channel only bigpanda Solid State 9 20th March 2006 02:24 AM
Symmetrical Clipping vdi_nenna Solid State 9 19th January 2001 07:17 AM
