Tubie Noobie
I am having a difficult time understanding why the influence of the top edge of the speaker contributes to a strong dip while the side edge doesn't.
Attached is two measurements of a D2904_710001 on a cardboard baffle. On the initial measurements, the tweeter was 6.75 inches down from the top. Using a flat baffle 10 inches wide. The tweeter is 23 inches from the bottom. There was a dip at 1900Kz. (blue line) Initialy the speaker was centered on the baffle, I then moved it off center by an inch. No matter what I did, I could not significantly change the dip. FYI I could not get 1/2" F10 felt to make a significant difference. I eventually added 4 inches to the top pf the baffle,and noticed a large reduction in the dip. I then bent the top portion of the baffle back 30 degrees about an inch from the speaker flange and the resulting curve is what is seen on the graph. (red line) Why does the top edge have such a dramatic effect? I would have thought that the side edges would have largest effect. I also have a dip at 9kHz which relates to the diameter of the dome. Any known way to help that?
Living Life Doing the Waltz in 4/4 meter. |
#2 |
Got any pictures of the speaker?
Dan |
#3 | |
You may find some help in here: "Understanding Cabinet Edge Diffraction" by Andy Unruh Dave |
#4 |
Tubie Noobie
Thanks,
Intersting read and useful. Attached is a graph showing the best response compared to adding felt triangle wedges. The wedges actually increased the resolultion of the diffraction interferance pattern in the frequency response graph. I posted this graph only because it is interesting. I am in the process of building a stiffer(heavier) baffle out of MDF to conduct more experiments. Cardboard seems to work, but being as flexible as it is I question its contribution to the measurements. I will also use my D2904/710003 in these tests as they have much less distortion. ( The d2904/710001 are horrible <2000Hz because I think I blew them in a previous speaker. They have an audible buzz down low ). The focus of this study will be (within the limits of my existing cabinets) how to minimize the diffraction effect in the mid/upper driver region 300Hz to 25kHz.
Living Life Doing the Waltz in 4/4 meter. Last edited by SGregory; 16th January 2010 at 05:37 PM. Reason: forgot the graph |
#5 | |
The final felt pattern that I used is shown in the 3-way design example at my site. Dave |
#6 |
The 2K to 20K Hz tweeter frequency range has a 0.68" to 6.7" wavelength, so minor physical baffle shape changes can affect a wide frequency range. The attached photo of a dipole with a slanted top baffle shows one designer's attempt to control diffraction without losing the front sound field audio details from the tweeter and upper midrange.
#7 |
Tubie Noobie
Thanks again Dave,
I just completed my test rig. I am going to repeat my initial measurements and then experiment with some of the stuff on your page. With my test rig I can play with many different configurations simplyby making a new insert that allows flush mounting of the driver. It also allows for tilting the baffle and rotating the baffle to measure off center responses. I'll see if I can get similar results to confirm yours.
#8 |
Tubie Noobie
Based on my inital measureents last night, the speak shown by LineSource makes sense. The top of the speaker is exactly what I did to eliminate the dip.
I like the AMP too
#9 | |
Dave |
#10 |
Tubie Noobie
I think I may have answered my initial question. With my original set-up, tilting back the cardboard stiffened the baffle. With my new rig I was unable to repeat the effect of tilting the top back and cancelling the dip. I also think that my original set-up resonated. The new one is filled with sand.
Out of the new stand comes some new questions. In graph 1 I compare a 15 degree tilted baffle, with a vertical baffle. With the speaker centered and offset. When the baffle is tilted a dip appears at 2200Hz (Which is exactly as my as-built speaker shows). Off centering the driver helps up higher >3500Hz but does not impact the 2200Hz dip. The second graph shows the application of felt similar to dlr's site. In my case I am using F10 felt. There is a flattening at the higher frequencies above 6kHz, but I picked up a spike around 4100Hz. I need to go back and test but this may be related to the tilted baffle or felt spacing that is too close to the same. Interesting Stuff.....I will post pics of the rig when I get my camera back.
| diffraction control | dry martini | Vendor's Bazaar | 3 | 21st June 2010 11:05 PM |
| Is this normal diffraction? | ch83575 | Multi-Way | 33 | 25th August 2006 05:01 PM |
| midwoofer diffraction | mazurek | Multi-Way | 2 | 9th April 2006 03:34 AM |
| roundover/diffraction question | morbo | Multi-Way | 5 | 14th December 2004 07:27 AM |
| How to minimize grill diffraction | Alain | Multi-Way | 12 | 13th July 2004 06:25 PM |
| Page generated in 0.12557 seconds (81.12% PHP - 18.88% MySQL) with 11 queries |
