I built a speaker with 14.6L volume.
The tuning should be 40Hz. The drive is SS8545-00 I put a port length 11CM and after that made calculation that the port length should be 7.3CM for 40Hz. 11CM port is suite for 33Hz. Would this mistake will have negative affect on sound ? Thanks. |
#2 |
Yes, the lower tuning will cause your low frequency response to have a peak, then a dip, rather than a smooth rolloff. You should double check your calculations, then trim the port to the appropriate length.
#3 | |
I think there are a few versions of that woofer - as you see, there is no peak and dip
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#4 |
Internal port diameter is 3.6CM.
#5 |
I don't hear nasty noises but i do feel that sound is
sometimes dip. then i moved the speakers from the back wall and its sound much better but i fill it's sound little strange. I must say that my room acoustic is very bad. The XO is from here: http://www.speakerbuilding.com/conte...1/net_draw.gif |
#6 |
Oops - ignore me, I'm way off the mark today.
How far away from the wall are your speakers? What side is the port on? |
#7 |
The port is on the back side.
The speakers are about 35 cm from back wall. What should i do ? trim the port to 7CM length or replace it with 4.6 port diameter (11 cm length) ? I see in many sites that minimum port diameter should be 5CM. |
#8 |
For some design considerations/choice (when needed, more wood work, etc.) you could add a second port, let's say on the front or bottom, instead.
| port length | jwhit67 | Multi-Way | 1 | 6th March 2008 12:29 PM |
| Help with port length please | Bobhof | Multi-Way | 3 | 2nd May 2006 06:32 PM |
| port length | busterno1 | Multi-Way | 5 | 27th October 2003 08:05 PM |
| port length | dave k | Multi-Way | 13 | 13th July 2003 02:32 PM |
| Page generated in 0.08637 seconds (75.97% PHP - 24.03% MySQL) with 11 queries |
